Author Topic: Nthomas1 rebuild of heater controls  (Read 6249 times)
HBG
  • Megaposter
Re: Nthomas1 rebuild of heater controls
« Reply #15 on: 15 May, 2023, 11:03:05 AM »
Thanks Andrea, Tim.
The heater valve moves nicely and the heater blows hot and cold on demand. It could be that the cable is 'too short' so won't go all the way to the left. I can live with this for now but I'd like to fix the lever. I'll look around as Andrea suggests. Sugru also comes to mind....
Beckerman67
  • Member
« Reply #16 on: 15 May, 2023, 11:53:56 AM »
« Last Edit: 15 May, 2023, 12:05:02 PM by Beckerman67 »
HBG
  • Megaposter
« Reply #17 on: 15 May, 2023, 09:52:03 PM »
I wonder how you fit them? Think I'll try and make one from Milliput or similar.
Could do with a picture of the top lever if anyone has?
8
nthomas1
  • Rebel Poster
« Reply #18 on: 17 May, 2023, 12:55:06 PM »
Here are some pictures of the levers.
Norm Thomas
Ormskirk, Lancashire
Own:
1973 Fulvia S2 Coupe
HBG
  • Megaposter
« Reply #19 on: 17 May, 2023, 04:00:51 PM »
Thanks Norm. Looks like the top lever is the same as the bottom lever, just inverted. I'm going to look into mould making so I can model one out of Milliput. It's a small part that doesn't affect the car greatly, but I do like a project.
Wangler
  • Megaposter
« Reply #20 on: 17 May, 2023, 07:18:45 PM »
Wow, a full set of unbroken levers for a Fulvia. Now that’s a rare sight!
Fulvia Coupe 1976
Fulvia Coupe 3 1975
nthomas1
  • Rebel Poster
« Reply #21 on: 18 May, 2023, 08:47:06 AM »
Two good ones came with the car, two are courtesy of Omicron!
Norm Thomas
Own:
nthomas1
  • Rebel Poster
« Reply #22 on: 18 May, 2023, 08:51:31 AM »
It will be interesting to see how you get on. For information, my top and bottom levers (the same part as you say) were bought from Omicron for £38 each a couple of years back, plus vat and shipping of course.
Norm Thomas
Own:
HBG
  • Megaposter
« Reply #23 on: 31 May, 2023, 07:06:39 PM »
Here's a few pics of my job to add an end to the heater lever.
First make a cast of the lower lever with 'Blue stuff'. Heat it in hot water and it goes soft. When cool it goes hard. Ish.
HBG
  • Megaposter
« Reply #24 on: 31 May, 2023, 07:08:51 PM »
Use Milliput in the mould to make the part.
HBG
  • Megaposter
« Reply #25 on: 31 May, 2023, 07:12:42 PM »
Clean up the lever still fitted to the car. Used a Dremel, carefully.
HBG
  • Megaposter
« Reply #26 on: 31 May, 2023, 07:16:57 PM »
Slot the new end with a Dremel. Should have been a dentist. Glue it on with epoxy, leaving the sides clear for more Milliput.
HBG
  • Megaposter
« Reply #27 on: 31 May, 2023, 07:17:43 PM »
Glued on.
HBG
  • Megaposter
« Reply #28 on: 31 May, 2023, 07:23:18 PM »
Can't find the pic of the finished job! Tomorrow!
HBG
  • Megaposter
« Reply #29 on: 02 June, 2023, 07:17:27 PM »
Here it is. Not perfect but until I have to dismantle the dash top I'm happy.
