25 November, 2024, 03:29:07 PM
Welcome,
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News
forum.admin@lanciamc.co.uk
events@lanciamc.co.uk
- To Join the club go to
Home
Help
Search
Calendar
Register
Model Technical and Interest
Flavia
Firm brake pedal but no brake feel.
Pages: [
1
Go Down
« previous
next »
Author
Topic: Firm brake pedal but no brake feel. (Read 1854 times)
Angle Grinder
on:
07 May, 2023, 10:06:21 PM »
Wondering if anyone else recognises these symptoms.
Out driving in my Flavia coupe and every so often upon braking the pedal hard very little travel and felt very hard, but retardation felt alarmingly slight.
This scenario didn't happen everytime, but seemed to get worse if pedal was pumped.
Brake fluid is less than a year old and was thoroughly bled.
Front pads are new about 60 miles ago and do need to be better bedded in, but I don't think this would explain changing pedal feel.
Previous cars:
1983 Prisma 1600
1991 Thema 16v i.e. SE
1988 Thema 8v Turbo
1992 Thema 16v i.e.
1983 Gamma Coupe (manual)
1993 Thema VIS
1994 Thema VIS LE
1990 Thema 2.8
Kevinlincs
Re: Firm brake pedal but no brake feel.
Reply #1 on:
07 May, 2023, 10:49:01 PM »
Classic symptoms of a servo issue, either the servo itself has failed or the vacuum supply or one way valve has failed. Check the pipe from the manifold to the servo first off for splits in itself, if all appears OK then pull the pipe out of the servo which should give a sucking in of air sound if you've just had the engine running. If not then the vacuum is leaking out somewhere, or not getting there due to a failed one way valve.
Conversly if you have great vacuum and the pipe will hold to your finger with the engine running (via great vacuum) then your servo unit has failed. It's often in conjunction with rough engine running as it allows more air into the manifold than usual.
A very simple test to see if all is well with any servo brake system is to let the car idle and press and hold the brake pedal. Now switch the engine off and release then press the brake again. It should take a couple of presses to use all the available vacuum before the pedal goes hard.
If it makes no difference with yours if the engine is running or not then the vacuum assisted servo system is clearly nor working.
Hope that all makes sense and is of help.
Flavia 815 coupe
Delta integrale
Reply #2 on:
08 May, 2023, 06:55:26 AM »
I agree about the servo. These are “remote” and the push rod can corrode also the auxiliary air valve. It does not take much to stop these units working. If you get a repair kit it does not come with a new push rod. You need to measure the position of the old when before removing so the new one will be at the correct position. An incorrect position could result in the servo not releasing the brakes….
1998 Zeta 21. 12v
Jaydub
Reply #3 on:
08 May, 2023, 02:16:58 PM »
A simple test in addition to what Kevin suggested. Pump the pedal with engine off until you get a firm pedal, hold the pressure, start the engine. If the servo is working the pedal will sink down slightly due to suction on the servo diaphragm.
Jaydub
1600 HF. S2.
Angle Grinder
Reply #4 on:
08 May, 2023, 08:50:28 PM »
Fortunately, a few years ago, I bought one of the modern dual circuit servos recommended by the Consortium. Looks like it's time to fit it.
Previous cars:
1983 Prisma 1600
1988 Thema 8v Turbo
1992 Thema 16v i.e.
1993 Thema VIS
1994 Thema VIS LE
1990 Thema 2.8
lendickins
Reply #5 on:
22 July, 2023, 05:36:11 PM »
Servo for sure (try the diaphragm and/or split pipe into the diaphragm end) , although I would check the master cylinder seals at the same time.
Pages: [
1
Go Up
« previous
next »
Please select a destination:
General
=> About the LMC Forum
=> General Chat
=> Competition Information
=> Events 2024
=> Events 2025
=> Local Events
=> LMC Legends
=> Links
=> Pre-Lambda
=> Lambda
=> DiLambda
=> Artena and Astura
=> Augusta
=> Aurelia
=> Appia
=> Flaminia
=> Flavia
=> Fulvia
=> Stratos
=> Beta and Montecarlo
=> Gamma
=> Delta and Prisma
=> Ypsilon, Musa and Y10
=> Kappa
=> Thesis
=> Delta (2008-)
=> Commercial Vehicles
=> Other Lancia Models
Buy, Sell and Search
=> Members' cars for sale
=> Lancia vehicles for sale
=> Lancia vehicles required
=> Spares for sale
=> Spares required
Events Archive
=> Events 2011
=> Events 2012
=> Events 2013
=> Events 2014
=> Events 2015
=> Events 2016
=> Events 2017
=> Events 2018
=> Events 2019
=> Events 2020
=> Events 2021
=> Events 2022
=> Events 2023
Loading...
