23 December, 2024, 01:25:38 AM *
Author Topic: Valve clearances  (Read 1849 times)
FERGTS246
« on: 07 June, 2023, 11:21:11 AM »
Hi, I recently re-set my valve clearances. They were set at about 0.10 intake, 0.15 exhaust so I adjusted them to figures in the handbook 0.15 intake, 0.25 exhaust. They are now a bit noisy, whereas they weren't before.
I read sometime ago that the tappets are a bit noisy when set to correct gaps - does anyone agree with this? What is the main problem with having clearances a bit tighter than the official spec?
Thanks Chris
« Reply #1 on: 07 June, 2023, 12:21:30 PM »
Are they noisy after a 100 mile blast?
GG
« Reply #2 on: 07 June, 2023, 01:02:18 PM »
There is noisy, and then there is slightly noisy. It should sound like a nice sewing machine - if you don't hear anything, they are too tight. If it sounds disruptive, too loose. And yes, a bit quieter after a good warmup as noted above.
« Reply #3 on: 07 June, 2023, 02:37:20 PM »
To answer the question of too tight. Valves not seating fully. Too loose would affect valve timing slightly. Checked mine today also.
FERGTS246
« Reply #4 on: 07 June, 2023, 04:30:47 PM »
Hi All, thanks for your responses.
I haven't consciously checked after a 100 mile blast but I'm pretty sure I would have noticed if they had quietened down. I would say 'noisy' not 'very noisy'.
I'll take for a blast and check the noise.
FERGTS246
« Reply #5 on: 29 July, 2023, 12:46:18 PM »
I've bought a SPQR tappet adjuster to reset the tappets. As this tool allows for wear, I expect that the settings I found were probably correct and I've set them too big with just feeler gauges and therefore had not allowed for wear. Chris
« Reply #6 on: 29 July, 2023, 08:23:13 PM »
How does it work?
FERGTS246
« Reply #7 on: 30 July, 2023, 03:38:10 PM »
Richard, See attached pdf with instructions. Chris
* Gunson Click Tappet Adjuster Instructions.pdf (2833.57 KB - downloaded 107 times.)
