23 December, 2024, 06:31:31 AM *
Author Topic: gear box dismantling to replce 3rd gear set  (Read 1321 times)
donw
« on: 10 July, 2023, 03:44:36 PM »
Does anyone have notes on how to strip out to replace 3rd gear set.
how do the top & lay shafts come out are they pressed in as having removed everything that can be seen there is no movement.
Don Williamson
1917 Theta 2str
1926 Lambda torpedo
1930 Artena berlina
1933 Belna coupe
Mikenoangelo
« Reply #1 on: 11 July, 2023, 06:54:34 AM »
The gearbox bearings of the Augusta have a groove around the the outer race and are located axially by a peg which screws in through the side of the casing. A bit of heat from a hot air paint stripping gun also helps. I've no idea whether the Lambda is the same?
Hope this helps.
Mike Clark
Tony Stephens
« Reply #2 on: 12 July, 2023, 10:54:28 AM »
Sent you the Russ Meehan gearbox overhaul Bible.
