22 December, 2024, 04:29:51 PM
Welcome,
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News
forum.admin@lanciamc.co.uk
events@lanciamc.co.uk
- To Join the club go to
Home
Help
Search
Calendar
Register
Model Technical and Interest
Flaminia
Speedo Cable
Pages: [
1
Go Down
« previous
next »
Author
Topic: Speedo Cable (Read 1230 times)
dannels
Speedo Cable
on:
16 August, 2023, 08:39:01 AM »
Hi All,
I have a bouncing speedo needle and a ticking from the cable so I need to lubricate the cable. I have some white Litiium grease that should do the job.
Has anyone done this? I assume I can pull the cable out from the sleeve. Can I disconnect from the speedo and pull the centre cable out from this end or do I need to disconnect both ends?
All advice appreciated!
Dave
1961 Flaminia GT, 1966 Matra Djet V
Brian Long
Re: Speedo Cable
Reply #1 on:
17 August, 2023, 12:32:10 AM »
Hi Dave,
Don't use any grease or oil to lubricate speedo cable. It will work its way up the cable and gum up the mechanism.
Instead use powdered graphite such as it used to lubricate locks. Clean the cable and then dust on the powder as you reinsert it.
You should be able to undo outer sheath from behind the speedo and withdraw cable. When reinserting it make sure that it is fully seated at the gearbox end. The squared end at the speedo end should protrude about 3/8" from the end shroud.
However, in spite of the foregoing, a 'flicking' needle usually means that there is wear in the bearing in the speedo head. You might need to take the instrument to a speedo specialist...if you can find an old-school one!
Brian.
Kevinlincs
Re: Speedo Cable
Reply #2 on:
17 August, 2023, 07:17:05 PM »
I've had great service from these guys before
https://www.speedycables.com/
Don't rule out the outer cable having a kink or tightspot, they can also make a cable from your old one as I've had them do before.
Flavia 815 coupe
Delta integrale
Pages: [
1
Go Up
« previous
next »
Please select a destination:
General
=> About the LMC Forum
=> General Chat
=> Competition Information
=> Events 2024
=> Events 2025
=> Local Events
=> LMC Legends
=> Links
=> Pre-Lambda
=> Lambda
=> DiLambda
=> Artena and Astura
=> Augusta
=> Aurelia
=> Appia
=> Flaminia
=> Flavia
=> Fulvia
=> Stratos
=> Beta and Montecarlo
=> Gamma
=> Delta and Prisma
=> Ypsilon, Musa and Y10
=> Kappa
=> Thesis
=> Delta (2008-)
=> Commercial Vehicles
=> Other Lancia Models
Buy, Sell and Search
=> Members' cars for sale
=> Lancia vehicles for sale
=> Lancia vehicles required
=> Spares for sale
=> Spares required
Events Archive
=> Events 2011
=> Events 2012
=> Events 2013
=> Events 2014
=> Events 2015
=> Events 2016
=> Events 2017
=> Events 2018
=> Events 2019
=> Events 2020
=> Events 2021
=> Events 2022
=> Events 2023
Loading...
