30 December, 2024, 05:42:32 PM
Welcome,
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News
forum.admin@lanciamc.co.uk
events@lanciamc.co.uk
- To Join the club go to
Home
Help
Search
Calendar
Register
Lancia Motor Club
Model Technical and Interest
Fulvia
Lancia Fulvia Retrim
Pages: [
1
Go Down
« previous
next »
Author
Topic: Lancia Fulvia Retrim (Read 1471 times)
MartynT
on:
01 November, 2023, 12:54:04 PM »
Hi All,
I will be doing a full interior strip on my 1972 Fulvia S2 HF Coupe including new headlining with the seats, door cards etc going to Brian Cates for retrimming & I'm hoping I can get some guidance on the following points;
1) The floor pan section that surrounds the handbrake is currently exposed black painted metal - I assume this as per original design & is uncarpeted? If that is the case then was this piece of floor pan painted in a matt black paint?
2) I currently have some really tatty British Leyland(!?) non inertia real seatbelts that I will look to change. Is it acceptable to replace with inertia reel belts as replacements or would this detract from authenticity?
3) I am also going to refurb the dash as the current vinyl dash top is split. while I am doing this I'll look to make some repairs top faulty switches & replace the dial lamps as they are really dim - are there any other modifications etc that I need to consider while I have the dash out?
If there are any other hints. tips, advice members can offer it would be highly appreciated.
Regards,
Martyn.
HBG
Re: Lancia Fulvia Retrim
Reply #1 on:
01 November, 2023, 07:42:13 PM »
Hi Martyn.
As part of my work to make my Fulvia the best it can be for using, I've done a couple of things that could provide an answer to your questions.
I bought some automotive carpet to make some properly fitting overmats, and with an off cut made a tight fitting piece to cover the metal (which was body colour) between the hand brake and the seatbelt stalks.
I also replaced the original static belts with recoil. I bought the belts from a place in Essex at a very reasonable price and fitted them myself into the void behind the rear side panels. I had to carefully cut a slot in the side panels for the belt to exit. I'll try and find some pics. I found the static belts had to be loose to reach the choke or the radio and didn't feel they would protect me. I've kept the originals....but am never likely to use them again.
Last Edit: 03 November, 2023, 03:28:38 PM by peteracs
HBG
Reply #2 on:
01 November, 2023, 07:44:42 PM »
I wasn't happy as the red belts didn't quite retract enough as they were long. I replaced them with slightly shorter black belts.
The red ones are available if you want them?
Reply #3 on:
02 November, 2023, 10:48:26 AM »
I've used
http://safetybeltservices.com/contact.html
. It's a one man band who assembles belts from scratch with a wide range of colours and fittings. He remade my belts with the original buckles and even offered to include in the original manufacturer's label from my old belts for authenticity.
MartynT
Reply #4 on:
03 November, 2023, 09:15:45 AM »
Thanks for the comments so far guys.
Pages: [
1
Go Up
« previous
next »
Please select a destination:
General
=> About the LMC Forum
=> General Chat
=> Competition Information
=> Events 2024
=> Events 2025
=> Local Events
=> LMC Legends
=> Links
=> Pre-Lambda
=> Lambda
=> DiLambda
=> Artena and Astura
=> Augusta
=> Aurelia
=> Appia
=> Flaminia
=> Flavia
=> Fulvia
=> Stratos
=> Beta and Montecarlo
=> Gamma
=> Delta and Prisma
=> Ypsilon, Musa and Y10
=> Kappa
=> Thesis
=> Delta (2008-)
=> Commercial Vehicles
=> Other Lancia Models
Buy, Sell and Search
=> Members' cars for sale
=> Lancia vehicles for sale
=> Lancia vehicles required
=> Spares for sale
=> Spares required
Events Archive
=> Events 2011
=> Events 2012
=> Events 2013
=> Events 2014
=> Events 2015
=> Events 2016
=> Events 2017
=> Events 2018
=> Events 2019
=> Events 2020
=> Events 2021
=> Events 2022
=> Events 2023
Loading...
