14 December, 2024, 12:06:56 AM *
Author Topic: Worn Oil pump/Dist. Gear  (Read 1724 times)
LatheJon
« on: 20 November, 2023, 03:36:58 PM »
Hello, On my Engine the Gear which is attached to the Distributor drive shaft also drives the oil pump held in place with a pin, is badly worn. Do any owners know if these Gears are are available?
Many Thanks  John
« Reply #1 on: 21 November, 2023, 08:41:29 AM »
Can you post a photo and/or count the teeth - I have some new gears but need to check if it's the correct one
LatheJon
« Reply #2 on: 21 November, 2023, 09:46:04 AM »
Thanks Simon, The Gear has 18 teeth, about 30mm dia, 24mm high, on a 14mm shaft.
Regards,
John
« Reply #3 on: 23 November, 2023, 02:00:53 PM »
Unfortunately the only gears that are new are for the oil pump ... sorry. I may be able to find a good S/H distributer drive, but  you probably need the crankshaft gear as well ?? Again I will have S/H crank gears
Sebastien
« Reply #4 on: 23 November, 2023, 03:35:32 PM »
Have you tried Cavalitto?
See for example:
https://www.oldlanciaspares.com/997-lancia-APRILIA-ricambio-ingranaggio-comando-pompa-olio.php
He can also organize spares which are not on his website.
Jay
« Reply #5 on: 23 November, 2023, 03:58:24 PM »
I would say only about 5% of his stock is on the Cavalitto site
Julian Wood, Kingston, London
Hendrik
« Reply #6 on: 14 December, 2023, 09:19:50 PM »
I have these 2…
