impaw
« on: 26 November, 2023, 08:27:07 AM » |
Hello,
As I currently have my engine on a stand, running well, I thought it would be good to test that the dynamo an voltage regulator does a good job.
D+ from the dynamo, does that go to the "+" on the underside of the regulator, and DF on the dynamo to the other connection underside the regulator? ...and then 61 and 51 on the regulator to the battery?
« Last Edit: 26 November, 2023, 07:58:40 PM by impaw »
Torstein
1955 Aurelia B20 1966 Fulvia 1966 Fulvia rally/race car
impaw
« Reply #1 on: 27 November, 2023, 04:57:14 PM » |
hmmm I think I am wrong about these connections. If somebody have the time, could they check where D+ and DF from the Dynamo go on the voltage regulator?
Torstein
Kari
« Reply #2 on: 28 November, 2023, 08:14:24 AM » |
Please take a picture of the underside of the voltage regulator and post it here.
Karl
impaw
« Reply #3 on: 28 November, 2023, 08:59:21 AM » |
Hi, Picture attached. One of the connectors has a "+" mark, the other seems to be unmarked.
As I understand it 51 is the output from the regulator, and 61 is for the charging light.
So my bet, as of now is
Dynamo "D+" -> VR "+" Dynamo "DF" -> VR unmarked on underside
Torstein
Kari
« Reply #4 on: 28 November, 2023, 10:00:44 AM » |
Your bet is right. Make sure all ground connections exist and the other wire from the charging lamp is connected to ignition+ (15) Is it a Bosch regulator? Karl
impaw
« Reply #5 on: 28 November, 2023, 10:02:29 AM » |
Great, thank you! It is a Marelli regulator
IŽll try to hook it up in a day or two and see if I can get some charging.
Torstein
impaw
« Reply #6 on: 11 May, 2024, 08:06:52 AM » |
Others parts of the project got in the way, and I have not made this work yet. I suspect the regulator is faulty, but in order to rule out the dynamo- how much voltage should the dynamo itself make, without the regulator attached?
Torstein
impaw
« Reply #7 on: 11 May, 2024, 10:26:22 AM » |
. Measured about 60mV between the two connectors on the dynamo, at idle, and about 250mV at 3000rpm
« Last Edit: 11 May, 2024, 10:32:49 AM by impaw »
Torstein
« Reply #8 on: 11 May, 2024, 03:39:39 PM » |
Over the years I have tried to find to find someone somewhere in Europe who can repair the OE Aurelia Marelli voltage regulators without success. So these days, if I have a problem I fit a modern sold state regulator inside the original Marelli casing which has been well described by Tim Heath in the UK LMC magazine and also on this Forum I recall. The dynamos themselves rarely need more than new bearings and brushes. Chris
Parisien
« Reply #9 on: 11 May, 2024, 05:14:21 PM » |
That's very useful Chris, thank you, can you let me know which edition Tim's update appeared in?
P
Frank Gallagher
impaw
« Reply #10 on: 11 May, 2024, 05:34:57 PM » |
Thank you Chris, this sounds like the way to go! Thank you
Torstein
« Reply #11 on: 11 May, 2024, 08:27:44 PM » |
I agree!
