as mentioned to you , my Australian friends have already done this by hard chroming the camshaft over size the line boring the head to suit with no issues at all , another has bored out the head and retro fitted bronze bearings to take up the wear , you need to be careful as the heads do wear and you get a huge oil pressure drop as a result , this is the same on Astura engines too where the cam bearings and rocker shafts wear , dropping oil pressure reading at the head alarmingly , any good engine specialist would be able to help you , Bradbury's who are doing the white metaling on my Belna engine would certainly sort it for you
