14 December, 2024, 11:31:38 PM *
Author Topic: MOT emissions test  (Read 906 times)
RRomanis
« on: 17 May, 2024, 09:26:47 PM »
Hi all
At a recent MOT my S3 recently struggled on the missions test, specifically the HC (hydrocarbon) levels. It seems there’s a set target level for all petrol vehicles by age category.
Has anyone else had a similar problem with their Fulvia and there any easy way to remedy it?
Noting that the cars are MOT exempt but I find it a worthwhile exercise to have someone else look the car over once a year.
neil-yaj396
Committee
« Reply #1 on: 18 May, 2024, 10:45:32 AM »
If it fails the HC test doesn't that mean that it's running way too rich? Good tune up of the carbs should sort it unless of course they are really warn; jets spindles etc.
Dave Gee
« Reply #2 on: 18 May, 2024, 06:03:18 PM »
 Having just had my 1972 Fulvia MOT'd yesterday, I understand that the MOT is purely a checklist of visual inspections. Mine did not have an emissions test (none of my classic cars do,) as they would not meet the emissions requirements of much more efficient modern engines.
Dave Gee
dhla40
« Reply #3 on: 19 May, 2024, 07:49:46 AM »
The last MOT emission test I had the limits were 4.5% CO and 1200ppm HC, these are related in that as CO goes up HC comes down so if you have CO below 4.5 you might be able to tweak the mixture a bit richer to help bring the HC down.
Sean
1976 1.3s coupe
1973 1.3s coupe
1982 montecarlo project
1976 alfa GT
1981 alfa spider
RRomanis
« Reply #4 on: 20 May, 2024, 07:34:56 AM »
Hi all
Thanks for responses so far.
A follow up question, as my interpretation of a couple of the responses seems to contradictory.
My understanding was that is the HCs are to high, I’d need to turn down the mixtures. This seems to be implied in 1 of the responses.
However, a later response suggests the opposite ie turning UP the mixtures in order to reduce HCs.
Can anyone confirm definitively please?
dhla40
« Reply #5 on: 20 May, 2024, 08:49:54 AM »
You need to find an MOT garage that will let you fiddle with the carbs during the test, most places are only used to modern cars and have no clue. Luckily my local was happy for me to adjust and it may have been a calibration issue with the tester they were using but my CO was 3% with high HC and by tweaking the CO up to 4.5 it brought the HC down.
Sean
1976 1.3s coupe
1973 1.3s coupe
1976 alfa GT
1981 alfa spider
Beckerman67
« Reply #6 on: 20 May, 2024, 09:44:57 AM »
Dave Gee
Just found this on the Government Website if it helps:
"Petrol before 1975 tested by sight"
* Screenshot 2024-05-20 at 10-25-55 Emissions testing.png (70.22 KB, 627x816 - viewed 48 times.)
« Last Edit: 20 May, 2024, 09:49:09 AM by Beckerman67 » Logged
Jaydub
« Reply #7 on: 20 May, 2024, 10:31:02 AM »
Hydro carbons are unburnt fuel caused by an out of tune engine, not necessarily a rich mixture. It could be uneven compressions, badly seating valves, tight valve clearances, worn spark plugs, air leaks, incorrect ignition timing etc etc. As has been suggested, it may help to adjust the mixture to get the engine to run more evenly, but everything else needs to be correct first and then balance and tune the carburettors. Also make sure the engine is fully up to temperature before the emissions are checked, and not having sat around waiting for the test to be carried out. Most MOT testers, especially the younger ones, have no knowledge or understanding of carburetted engines.
1600 HF. S2.
Page created in 0.065 seconds with 21 queries.
