Author Topic: Flavia 2000 Water Pump.  (Read 998 times)
Caracad
  • Senior Member
« on: 20 May, 2024, 12:58:16 PM »
Water pump is making a noise. It’s also possible to wiggle the pulley by hand so some play there.
It was refurbished before I got the car and isn’t leaking. I assume the bearing has worn prematurely.
Any advice anyone?
Mark.
Brian Long
  • Senior Member
  • Aurelia B12, Flavia 2000 Coupe
Re: Flavia 2000 Water Pump.
« Reply #1 on: 22 May, 2024, 05:27:59 AM »
I'd suggest removing it and replacing bearings with sealed type.
You can get a bit of movement and no leakage now because the seal face is spring loaded/ self-aligning to some extent.
