14 December, 2024, 06:41:18 PM
Welcome,
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News
forum.admin@lanciamc.co.uk
events@lanciamc.co.uk
- To Join the club go to
Home
Help
Search
Calendar
Register
Model Technical and Interest
Fulvia
engine splutter
Pages: [
1
Go Down
« previous
next »
Author
Topic: engine splutter (Read 1133 times)
Keithver
engine splutter
on:
21 May, 2024, 07:27:10 AM »
When changing down from 5th gear to 4th to overtake, my engine would splutter until I changed back up to 5th. I've just serviced the car. I see that the old plugs were Champion N9Y. on inspecting them they had all burnt pretty well. no indication of a rich mixture. I have fitted the specified N7Y plugs. Old and new plugs were set to 0.6mm gaps.
I took it for a drive and revved it to about 6000 rpm in all gears. I could not get it to splutter at all.
Just wondering - could the plugs make such a difference. I didn't fiddle with the carbs at all
'72 series 2 Fulvia 1,3s
lancianut666
Slow but rough
Re: engine splutter
Reply #1 on:
21 May, 2024, 04:39:49 PM »
Water in the petrol?
Keithver
Re: engine splutter
Reply #2 on:
22 May, 2024, 07:42:39 AM »
I don't think so. I drained the tank and didn't see any water
Re: engine splutter
Reply #3 on:
22 May, 2024, 07:44:13 AM »
Not really enough information.....
1998 Zeta 21. 12v
Keithver
Re: engine splutter
Reply #4 on:
22 May, 2024, 10:23:00 AM »
hi Tim. What other info can I send you to help you understand the problem better
Re: engine splutter
Reply #5 on:
22 May, 2024, 12:40:40 PM »
Is it happening all time you change from 5 to 4th? What carbs do you have the nasty emission ones?
What revs are you in in 5th when you change down. Does it also happen in other gears changing at same revs?
1998 Zeta 21. 12v
Keithver
Re: engine splutter
Reply #6 on:
22 May, 2024, 02:30:40 PM »
I have the standard Solexes - not the emission ones
When I change down from 5th I'm probably between 3 and 3500 RPM and it mainly happened when changing down from 4th.
As I said initially, the only thing I changed during the service was the plugs - to the correct N7Y's. Could it be that the plugs would make such a difference. More out of interest than anything else as the problem seems to be resolved now
Re: engine splutter
Reply #7 on:
22 May, 2024, 02:41:03 PM »
Incorrect valve timing can cause the Fulvia engine to "stagger" around 2000 rpm under load as the incorrect timing causes a hole in the torque curve....
1998 Zeta 21. 12v
Spider2
Re: engine splutter
Reply #8 on:
23 May, 2024, 12:19:51 PM »
Try driving with the headlights on!
I had splutter at 3,000 rpm. I have a 123 electronic ignition fitted and it was traced to the voltage regulator overvolting at high rpm causing the electronic ignition to cut out (they are very voltage sensitive). I noticed that it never spluttered at night. I changed to a modern solid state VR. Problem solved. What sort of VR do you have?
Pages: [
1
Go Up
« previous
next »
Please select a destination:
General
=> About the LMC Forum
=> General Chat
=> Competition Information
=> Events 2024
=> Events 2025
=> Local Events
=> LMC Legends
=> Links
=> Pre-Lambda
=> Lambda
=> DiLambda
=> Artena and Astura
=> Augusta
=> Aurelia
=> Appia
=> Flaminia
=> Flavia
=> Fulvia
=> Stratos
=> Beta and Montecarlo
=> Gamma
=> Delta and Prisma
=> Ypsilon, Musa and Y10
=> Kappa
=> Thesis
=> Delta (2008-)
=> Commercial Vehicles
=> Other Lancia Models
Buy, Sell and Search
=> Members' cars for sale
=> Lancia vehicles for sale
=> Lancia vehicles required
=> Spares for sale
=> Spares required
Events Archive
=> Events 2011
=> Events 2012
=> Events 2013
=> Events 2014
=> Events 2015
=> Events 2016
=> Events 2017
=> Events 2018
=> Events 2019
=> Events 2020
=> Events 2021
=> Events 2022
=> Events 2023
Loading...
