21 June, 2024, 08:22:58 PM
Welcome,
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News
forum.admin@lanciamc.co.uk
database.admin@lanciamc.co.uk
events@lanciamc.co.uk
- To Join the club go to
Home
Help
Search
Calendar
Register
Lancia Motor Club
Model Technical and Interest
Appia
Replacing Series 3 brake light switch
Pages: [
1
Go Down
« previous
next »
Author
Topic: Replacing Series 3 brake light switch (Read 295 times)
sllim1946
on:
22 May, 2024, 02:24:02 PM »
This is a fairly easy task but I thought i'd write it up anyway.
Access to the switch is very easy once the front wheel has been removed. Lift up brake fluid reservoir pressure plunger and lock up with mole grips or similar.
Disconnect the wires from the switch and remove it using a 24mm open ended spanner (An 15/16 AF will work just as well at 24.2mm). Replace the copper washer and attach the new switch. Before tightening fully, release the fluid reservoir pressure plunger and allow fluid to flow from switch to avoid possibility of air in the system then fully tighten.
Connecting wires will need to have connectors cut off and replaced with modern 6mm spade type – use blue insulated ones. As wires are quite short cut just above the original connectors.
Brian Mills
Last Edit: 22 May, 2024, 03:00:38 PM by sllim1946
1961 Appia Berlina S3
Re: Replacing Series 3 brake light switch
Reply #1 on:
22 May, 2024, 03:35:23 PM »
Good tip about bleeding the fluid from Brian. New brake light switches are available from the Appia Consortium.
Spider2
Reply #2 on:
23 May, 2024, 12:08:46 PM »
Is there a link to Brian's tips about bleeding the brakes. I have just replaced the seals in the master cylinder and changed the pressure switch but cannot successfully bleed the brakes. I have about 80% pedal travel before any resistance is felt. There appears to be no air in the system and the last 20% of pedal movement does lock up the drums. This is on a series 2
Reply #3 on:
23 May, 2024, 09:08:09 PM »
Sounds like you might have problems with the reservoir. If the seals are poor the pressure to bleed the brakes will not be maintained and you will find it tricky to get all the air out. As a rule when you pull the plunger on the top of the reservoir up it should stay up and you can then bleed the brakes as plunger is a piston acting down on the brake fluid via a spring and some brake seals. It might be the master cylinder bore is worn or the flexible hydraulic hoses are weak.
The Appia Consortium has most of the seals you might need as well as new hoses.
Spider2
Reply #4 on:
24 May, 2024, 07:49:08 AM »
The piston in the reservoir does not stay up so bled the brakes the old way by a friend pumping the brake pedal. Should I blead the brakes by pulling up the piston and clamping it? Problem maybe in the resrvoir?
I have replaced the seals in the master cylinder and the the wheel cylinders look good.
Dikappa
Reply #5 on:
24 May, 2024, 03:28:12 PM »
best to check and rebuild the reservoir, as the piston should always be up, also during normal use. if not your brake will not feel correct.
Pages: [
1
Go Up
« previous
next »
Please select a destination:
General
=> About the LMC Forum
=> General Chat
=> Competition Information
=> Events 2024
=> Events 2025
=> Local Events
=> LMC Legends
=> Links
=> Pre-Lambda
=> Lambda
=> DiLambda
=> Artena and Astura
=> Augusta
=> Aurelia
=> Appia
=> Flaminia
=> Flavia
=> Fulvia
=> Stratos
=> Beta and Montecarlo
=> Gamma
=> Delta and Prisma
=> Ypsilon, Musa and Y10
=> Kappa
=> Thesis
=> Delta (2008-)
=> Commercial Vehicles
=> Other Lancia Models
Buy, Sell and Search
=> Members' cars for sale
=> Lancia vehicles for sale
=> Lancia vehicles required
=> Spares for sale
=> Spares required
Events Archive
=> Events 2011
=> Events 2012
=> Events 2013
=> Events 2014
=> Events 2015
=> Events 2016
=> Events 2017
=> Events 2018
=> Events 2019
=> Events 2020
=> Events 2021
=> Events 2022
=> Events 2023
Loading...
