22 June, 2024, 10:33:34 AM
Welcome,
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News
forum.admin@lanciamc.co.uk
database.admin@lanciamc.co.uk
events@lanciamc.co.uk
- To Join the club go to
Home
Help
Search
Calendar
Register
Lancia Motor Club
Model Technical and Interest
Appia
Replacing Rear Dampers
Pages: [
1
Go Down
« previous
next »
Author
Topic: Replacing Rear Dampers (Read 139 times)
sllim1946
on:
22 May, 2024, 02:59:57 PM »
Thought the following might be of interest:-
The rear dampers are located at the top in circular turrets with the securing nuts under rubber covers in the boot. The lower nuts are underneath the mounting brackets attached to the rear axle.
Firstly remove the spare wheel and top mount covers from the boot. Remove rear wheels and jack up axle and install axle stands.
The lower securing nuts need a 19mm spanner and a 8mm open ended one to slip onto the flats on the lower shaft. Even after application of copious amounts of Freeze Release spray the torque required to turn the 19mm nut was too much for the 8mm spanner locked against the brake drum and it turned on the flats. The solution was to use a pair of Mole grips set very tight and locked against the axle.
The upper mounts are more complicated. The damper upper body is secured to the turret by a hollow collared nut. By using a light and a mirror it is possible to see the top of the upper shaft which is hexagon shaped with a slot for a flat screwdriver. A screwdriver cannot created anywhere near enough torque to move the shaft in the nut and the hexagonal shaft head is impossible to reach without a special thin walled long socket – hence why the workshop manual states that a special Lancia tool is needed.
Freeze release spray is only useful when applied down through the top of the nut not around the washer area.
Eventually the solution turned out to be locking a 24mm (or 15/16 AF which is 24.2mm) spanner on the nut by supporting it on a suitable block of wood and jamming against the bulkhead between boot and cabin on RHS and onto the inner wing on the LHS. The task is then to turn the damper upper body under the car by using a small bicycle chain type oil filter wrench (£6.35 from B&Q inc. p&p!). Even using this requires too much torque for the chain which slides on the chain locating pegs. This problem is solved by clamping chain to tool pegs with the trust Moles! Problem solved and damper removed.
Fitting the Spax replacement sourced by the consortium is simple. Both upper and lower damper shafts have 6mm flats on the shafts and are secured via14mm spanner. The rubber bushes have slightly smaller diameter collars so need to be as central as possible in the mounting holes to minimise any minor misalignment.
Locating the adjustments screws towards to centre of the car gives access from under the rear. Set up adjustment is well described in the Spax document.
Brian Mills
1961 Appia Berlina S3
Re: Replacing Rear Dampers
Reply #1 on:
22 May, 2024, 03:33:49 PM »
Top info from Brian! The good news is the Appia Consortium still have new dampers available.
Pages: [
1
Go Up
« previous
next »
Please select a destination:
General
=> About the LMC Forum
=> General Chat
=> Competition Information
=> Events 2024
=> Events 2025
=> Local Events
=> LMC Legends
=> Links
=> Pre-Lambda
=> Lambda
=> DiLambda
=> Artena and Astura
=> Augusta
=> Aurelia
=> Appia
=> Flaminia
=> Flavia
=> Fulvia
=> Stratos
=> Beta and Montecarlo
=> Gamma
=> Delta and Prisma
=> Ypsilon, Musa and Y10
=> Kappa
=> Thesis
=> Delta (2008-)
=> Commercial Vehicles
=> Other Lancia Models
Buy, Sell and Search
=> Members' cars for sale
=> Lancia vehicles for sale
=> Lancia vehicles required
=> Spares for sale
=> Spares required
Events Archive
=> Events 2011
=> Events 2012
=> Events 2013
=> Events 2014
=> Events 2015
=> Events 2016
=> Events 2017
=> Events 2018
=> Events 2019
=> Events 2020
=> Events 2021
=> Events 2022
=> Events 2023
Loading...
