03 July, 2024, 07:29:27 AM
Welcome,
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News
forum.admin@lanciamc.co.uk
database.admin@lanciamc.co.uk
events@lanciamc.co.uk
- To Join the club go to
Home
Help
Search
Calendar
Register
Lancia Motor Club
Model Technical and Interest
Fulvia
Coupe door adjustment and top hinge spring
Pages: [
1
Go Down
« previous
next »
Author
Topic: Coupe door adjustment and top hinge spring (Read 327 times)
Simon B
on:
28 May, 2024, 08:55:45 PM »
I was trying to raise the drivers door at the leading edge a couple of mm, without success as seem to have run out vertical adjustment on the bottom hinge. I also noticed that the hinge spring was broken, the passenger side spring is the same. What’s the purpose of the spring, is it to just ease the door as it opens to prevent it hitting the check strap too hard?
I only had the door trim panel off, so only attempted to adjust the hinges on the door. If I remove the hinge cover, is there also vertical adjustment where the hinges attach to the body? Does anyone have any suggestions/good techniques for making small adjustments to door position?
Many thanks
dhla40
Re: Coupe door adjustment and top hinge spring
Reply #1 on:
29 May, 2024, 06:41:22 AM »
I think the hinges are welded to the body, the spring is to hold the door when fully open.
Dean
1976 1.3s coupe
1973 1.3s coupe
1982 montecarlo project
1976 alfa GT
1981 alfa spider
Reply #2 on:
29 May, 2024, 06:03:12 PM »
If you can waggle the door in the vertical plane then the hinge pins need replacing first.
1998 Zeta 21. 12v
Simon B
Reply #3 on:
30 May, 2024, 08:20:03 PM »
Thanks Dean, I can see the heads of the fixing screws on the body so fairly sure the hinges aren’t welded, something holding the door open would be good, don’t think the doors have ever stayed open on a slope!
Thanks Tim, no discernible vertical play in the hinges on the door. I’ve made a very small improvement and have now put the trim panel back on the door. New springs and further tweaking can wait until winter!
Pages: [
1
Go Up
« previous
next »
Please select a destination:
General
=> About the LMC Forum
=> General Chat
=> Competition Information
=> Events 2024
=> Events 2025
=> Local Events
=> LMC Legends
=> Links
=> Pre-Lambda
=> Lambda
=> DiLambda
=> Artena and Astura
=> Augusta
=> Aurelia
=> Appia
=> Flaminia
=> Flavia
=> Fulvia
=> Stratos
=> Beta and Montecarlo
=> Gamma
=> Delta and Prisma
=> Ypsilon, Musa and Y10
=> Kappa
=> Thesis
=> Delta (2008-)
=> Commercial Vehicles
=> Other Lancia Models
Buy, Sell and Search
=> Members' cars for sale
=> Lancia vehicles for sale
=> Lancia vehicles required
=> Spares for sale
=> Spares required
Events Archive
=> Events 2011
=> Events 2012
=> Events 2013
=> Events 2014
=> Events 2015
=> Events 2016
=> Events 2017
=> Events 2018
=> Events 2019
=> Events 2020
=> Events 2021
=> Events 2022
=> Events 2023
Loading...
