Any tips on doing this and does it give access to rear of instruments as trying to sort non working temp guage. There is a mention of a guide in the forum. Many thanks
There isn't any need to remove the dashboard top t ogain access to the instrument cluster.
Firstly, disconnect the battery.
To access the instrument cluster you first need to remove the two round fasteners that are on the dimmer and tachometer reset button. There is anotiher nut inside the glove box. Carefully remove the wooden fascia. The rev, counter, speedo and instrument cluster are screwed down with self tapers.
Removing the dashboard top is fairly straightforward, if not tricky. There are only two 8mm or 10mm bolts holding it down. Access is from the footwell and inside the glove box. You may have to remove the radio, if one is fitted. The two air vents need to be removed and they are held in by clips just inside the vents.
The top can be stubborn and care is needed because the foam is old, probably brittle and can be easily damaged. Especially around the vent holes which is thinner is section.
