14 December, 2024, 05:49:53 AM *
Author Topic: Oil pressure build up  (Read 630 times)
Spider2
« on: 08 June, 2024, 07:08:06 AM »
I changed my oil filter recently and ever since the oil pressure has taken a long time to build up on engine start (8-9 seconds). It is as if the filter keeps draining after the engine is switched off. Apparantly there is an anti drain valve in the filter housing but I cannot work out where it is from the parts diagram. Any clues?
« Reply #1 on: 08 June, 2024, 08:52:40 AM »
It relies on the anti drain flap in the filter and the long tube in the housing. A lot of compatible filters are only compatible in size and thread..... What filter did you fit?
Spider2
« Reply #2 on: 08 June, 2024, 09:53:38 AM »
I copied the number from the old filter which had no problem: Bosch P 4063. Long number 0 451 104 063.
I have to admit I bought 2 off e-bay for an amazingly good price. I now notice that they were made in Poland. I suspect you are correct about it being compatable in size and thread only. Teach me for trying to be economical.
Who sells 100% correct ones and what should I be looking for on the box? Also what part number is recommended?
Spider2
« Reply #3 on: 13 June, 2024, 12:42:42 PM »
Thanks Tim, you were spot on in your diagnosis of my very slow oil pressure buildup.  I replaced the filter like for like a few months ago (Bosch P4063). The first one came as a spare with the car when I bought it and worked fine. I bought a replacement on ebay and this is the one that caused the problem.
I have just replaced the filter with a Flamm FT4403 bought from a very reputable supplier and the oil pressure build up is now almost instantaneous.
I guess the lesson for all of us is stay away from cheap ebay spares.
