08 September, 2024, 01:09:02 AM
Welcome,
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News
forum.admin@lanciamc.co.uk
events@lanciamc.co.uk
- To Join the club go to
Home
Help
Search
Calendar
Register
Lancia Motor Club
Model Technical and Interest
Fulvia
Fuel sender orientation.
Pages: [
1
Go Down
« previous
next »
Author
Topic: Fuel sender orientation. (Read 429 times)
HBG
on:
25 June, 2024, 09:15:45 AM »
Hi folks.
I replaced my fuel sender as the old one was all over the place when below half a tank. The new one from Ricambio is a slightly different design but went in the same orientation as the old one came out, that is to say between 4 and 5 o'clock when standing at the back of the car. Is this correct and would a 3 o'clock be better to get less effect from fuel sloshing about? The red light, which is now working again came on with 10 litres still in the tank (I'd just added 28 litres fill the tank), is this a bit premature?
Thanks.
Re: Fuel sender orientation.
Reply #1 on:
25 June, 2024, 09:57:31 AM »
5-10 litre red light is "normal". From memory the sender goes in 3oclock.... It needs not to hit any of the baffling...
1998 Zeta 21. 12v
HBG
Reply #2 on:
25 June, 2024, 10:13:41 AM »
When I've used a bit of fuel I'll move it round. I've cleaned up the original Jaeger sender and it is now working again, tempted to put that back in. It's a surprisingly delicate device, didn't expect the electrics to be submerged in fuel the whole time.
Was also good to have a look inside the tank. The bottom, which is the bit I can see is mostly rust free with a little showing in the stamped recesses. My recently changed fuel filter did show some dirt from the tank.
HBG
Reply #3 on:
28 July, 2024, 09:04:53 PM »
Got back from a lovely run to Stratford upon Avon today and took advantage of a quiet evening to adjust the orientation of the fuel sender. I hadn't realised that there was a box shaped baffle with a slot in it for the sender float to sit in until I tried to achieve the 3 o'clock position. Initially the arm rubbed on the side of the slot so I tweaked the arm, but even then I can't be sure it clears when it's bolted down. Time will tell.
I also noticed that the original Jeager sender has a bend in the arm that the replacement does not. Hoping the straight arm of the new sender doesn't foul the bottom of the slot and never drop enough to show an empty tank.
Pages: [
1
Go Up
« previous
next »
Please select a destination:
General
=> About the LMC Forum
=> General Chat
=> Competition Information
=> Events 2024
=> Events 2025
=> Local Events
=> LMC Legends
=> Links
=> Pre-Lambda
=> Lambda
=> DiLambda
=> Artena and Astura
=> Augusta
=> Aurelia
=> Appia
=> Flaminia
=> Flavia
=> Fulvia
=> Stratos
=> Beta and Montecarlo
=> Gamma
=> Delta and Prisma
=> Ypsilon, Musa and Y10
=> Kappa
=> Thesis
=> Delta (2008-)
=> Commercial Vehicles
=> Other Lancia Models
Buy, Sell and Search
=> Members' cars for sale
=> Lancia vehicles for sale
=> Lancia vehicles required
=> Spares for sale
=> Spares required
Events Archive
=> Events 2011
=> Events 2012
=> Events 2013
=> Events 2014
=> Events 2015
=> Events 2016
=> Events 2017
=> Events 2018
=> Events 2019
=> Events 2020
=> Events 2021
=> Events 2022
=> Events 2023
Loading...
