21 September, 2024, 05:33:44 AM
Welcome,
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News
forum.admin@lanciamc.co.uk
events@lanciamc.co.uk
- To Join the club go to
Home
Help
Search
Calendar
Register
Model Technical and Interest
Aurelia
Ignition barrel question
Pages:
1
2
Go Down
« previous
next »
Author
Topic: Ignition barrel question (Read 1532 times)
Sliding Pillar
Re: Ignition barrel question
Reply #15 on:
28 July, 2024, 07:59:50 AM »
Hi David, here's a photo of the dynamo clamping nut. You need to loosen the rod with the wedge on the end and remove it.
1955 Aurelia
1961 Lamborghini
DavidHill
Reply #16 on:
28 July, 2024, 03:37:50 PM »
Many thanks for the picture, i extracted the wedge and then the Alternator. will update once its inspected/repaired
will
Reply #17 on:
29 July, 2024, 06:41:56 PM »
David
You will have to losen the clamp right off and take the pulley wheel off the dynamo/ alternator
and extract the dynamo/ alternator out from back towards the gearbox
will
Aurelia B20 4th Series Appia 2nd Series Kappa Coupe 3.0 24v V6
DavidHill
Reply #18 on:
19 August, 2024, 01:14:22 PM »
Update on the Alternator. J Morgan and sons turned it round quickly, there was apparently a fault in the diode. I refitted it over the weekend and all is now back to normal and the B20 is running well again. So the odd fault with the ignition warning light was entirely down to the Alternator fault… thanks for all the advice!
Brian Long
Reply #19 on:
20 August, 2024, 04:06:57 AM »
You shouldn't have removed the split pin. It is there to help retract the wedge and is why the hollow bolt is so long.
When you replace the wedge and bolt do not overtighten it, just nip it up firmly.
Brian Long
Reply #20 on:
21 August, 2024, 07:22:47 AM »
....further to my previous reply, there should also be a washer under the spilt pin. Next time you have to remove the generator, just keep on undoing the elongated nut and it will retract the wedge.
Pages:
1
2
Go Up
« previous
next »
Please select a destination:
General
=> About the LMC Forum
=> General Chat
=> Competition Information
=> Events 2024
=> Events 2025
=> Local Events
=> LMC Legends
=> Links
=> Pre-Lambda
=> Lambda
=> DiLambda
=> Artena and Astura
=> Augusta
=> Aurelia
=> Appia
=> Flaminia
=> Flavia
=> Fulvia
=> Stratos
=> Beta and Montecarlo
=> Gamma
=> Delta and Prisma
=> Ypsilon, Musa and Y10
=> Kappa
=> Thesis
=> Delta (2008-)
=> Commercial Vehicles
=> Other Lancia Models
Buy, Sell and Search
=> Members' cars for sale
=> Lancia vehicles for sale
=> Lancia vehicles required
=> Spares for sale
=> Spares required
Events Archive
=> Events 2011
=> Events 2012
=> Events 2013
=> Events 2014
=> Events 2015
=> Events 2016
=> Events 2017
=> Events 2018
=> Events 2019
=> Events 2020
=> Events 2021
=> Events 2022
=> Events 2023
Loading...
