Does anyone know if my wipers are working as they should on my S3.
The top position of the stalk is off, the first one down gives what I guess is a normal speed of sweep, but it is intermittent, with about a two second delay between sweeps. The second one down gives a moderately fast speed. It makes no difference if the engine is running.
There is however no mention of an intermittent wiper function in the original owners handbook I have for the S3 and there is no sign of anything in the wiring diagram I have. The original owners handbook shows the “neutral” stalk position as being in the middle which is different to the way that mine works!
If I unplug the connection block close to the motor and wire the motor directly to a 12V power source using the Grey wire they run slow with no intermittency. With the Blue wire, the wipers go fast.
Are the wipers working as they should?
