Author Topic: Bloster Ignition Switch for Flavia 2000 Coupe  (Read 1117 times)
Brian Long
  • Senior Member
  • Aurelia B12, Flavia 2000 Coupe
« on: 08 September, 2024, 05:15:08 AM »
Does anyone have for sale the key barrel and contact body for a Bloster steering lock/ignition switch assembly for a Flavia 2000 coupe?
In the past someone has removed the original five terminal switch body and key barrel and replaced it with a two-position switch albeit still with the push-to-start function.
Thanks in anticipation
Brian Long
Brian Long
  • Senior Member
Re: Bloster Ignition Switch for Flavia 2000 Coupe
« Reply #1 on: 24 September, 2024, 03:18:48 AM »
All OK. Turns out that a previous owner had incorrectly reinstalled key barrel and hadn't lined up the anti-theft mechanism.
