What distributer are you using? The original or an electronic one like a 123. If electronic suggest you use a new digital voltage regulator as electronic ignition is VERY voltage sensitive. Too high a voltage causes it to momentarily cut out. I had this problem and it took me an age to trace. With new VR the problem is solved.
