Author Topic: Fulvia - misfire when hot / traffic jam  (Read 2171 times)
Keithver
  • Senior Member
Re: Fulvia - misfire when hot / traffic jam
« Reply #15 on: 13 April, 2025, 01:36:56 PM »
sounds like a possibility. When I assembled the car. I had nothing on cylinder 1 on idle. I took the carbs to a specialist to have everything properly internally cleaned. THat did the trick. Firing on all cylinders now - happiness
'72 series 2 Fulvia 1,3s
Spider2
  • Megaposter
« Reply #16 on: 14 April, 2025, 02:23:44 PM »
What distributer are you using? The original or an electronic one like a 123. If electronic suggest you use a new digital voltage regulator as electronic ignition is VERY voltage sensitive. Too high a voltage causes it to momentarily cut out. I had this problem and it took me an age to trace. With new VR the problem is solved.
nistri
  • Megaposter
« Reply #17 on: Yesterday at 07:37:11 AM »
The carbs may need balancing with a vacuum gauge. Slightly undo the idle screw for cylinder #2 to increase fuel delivery.
Andrea Nistri
Ardea S2
Appia S2
Fulvia GTE
Fulvia Sport 1.3 S
Fulvia Montecarlo
Fulvia Coupe 1.3 S
