27 November, 2024, 04:40:29 AM
Welcome,
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News
forum.admin@lanciamc.co.uk
events@lanciamc.co.uk
- To Join the club go to
Home
Help
Search
Calendar
Register
Lancia Motor Club
Model Technical and Interest
Aurelia
B20 Battery spec
Pages: [
1
Go Down
« previous
next »
Author
Topic: B20 Battery spec (Read 289 times)
DavidHill
B20 Battery spec
on:
08 November, 2024, 05:32:19 PM »
I have decided to go back to using a dynamo on my B20 after having used an alternator for some years. I have had my dynamo refurbished by J Morgan and Sons in Dorking (they did a good job on my Aprilia's dynamo). The expert there recommended not fitting too high an amp hour capacity battery to the B20 as over time that would wear out the dynamo (he suggested/estimated around 45 amp hours). Does anyone know the Amp hour specification for the B20's battery?? The manual lists a Marelli battery but not its spec...
Brian Long
Re: B20 Battery spec
Reply #1 on:
12 November, 2024, 05:42:43 AM »
Hi David,
For what it is worth, both the battery in my Aurelia and that in the Flavia 2000 coupe are 60 amp-hour, 600 Continuous Cranking Ampere (CCA) rated.
I have never experienced any generator problems with the B12; it still has the original M-M regulator.
Reply #2 on:
12 November, 2024, 08:19:32 AM »
I have the same David and far prefer the original dynamo MM set up to an alternator conversion. The only problem is finding someone to repair a faulty MM voltage regulator ( even in Italy this seems impossible) but they are pretty reliable and if necessary you can replace the internals with a modern solid state conversion.
Brian Long
Reply #3 on:
13 November, 2024, 06:34:06 AM »
A Bosch regulator, as I understand it, has been used provided that the generator's internal field winding connections are changed so that the regulator operates between the negative side of the field winding and ground.
Pages: [
1
Go Up
« previous
next »
Please select a destination:
General
=> About the LMC Forum
=> General Chat
=> Competition Information
=> Events 2024
=> Events 2025
=> Local Events
=> LMC Legends
=> Links
=> Pre-Lambda
=> Lambda
=> DiLambda
=> Artena and Astura
=> Augusta
=> Aurelia
=> Appia
=> Flaminia
=> Flavia
=> Fulvia
=> Stratos
=> Beta and Montecarlo
=> Gamma
=> Delta and Prisma
=> Ypsilon, Musa and Y10
=> Kappa
=> Thesis
=> Delta (2008-)
=> Commercial Vehicles
=> Other Lancia Models
Buy, Sell and Search
=> Members' cars for sale
=> Lancia vehicles for sale
=> Lancia vehicles required
=> Spares for sale
=> Spares required
Events Archive
=> Events 2011
=> Events 2012
=> Events 2013
=> Events 2014
=> Events 2015
=> Events 2016
=> Events 2017
=> Events 2018
=> Events 2019
=> Events 2020
=> Events 2021
=> Events 2022
=> Events 2023
Loading...
