22 December, 2024, 03:51:01 PM *
Author Topic: Advice: S1 Fulvia engine sticks  (Read 364 times)
julian67
« on: 04 December, 2024, 04:39:05 PM »
Yesterday I started my S1 Fulvia engine easily for about 3 minutes but was smokey. I put it down to cold weather & choke out
Today, it would not start. Oil is clean & level is normal.
I removed / checked starter motor - works fine. Then I put a screwdriver on the flywheel teeth and it moved back & forth.. Replaced the starter but it would not turn over.
Anyone any idea as to what it could be? Or what else I can check?
Many thanks
« Last Edit: 04 December, 2024, 04:41:33 PM by julian67 » Logged
« Reply #1 on: 04 December, 2024, 04:50:50 PM »
Take the plugs out and see if it turns over.
julian67
« Reply #2 on: 04 December, 2024, 05:21:18 PM »
Mechanic just called to say when he removed the plugs, no 2 plugs was all smashed up and said something is stuck between the piston & sleeve.
Could it be a broken ring?
He's going to remove the head tomorrow.
LCR1967
« Reply #3 on: 05 December, 2024, 07:34:21 AM »
It could be, but I doubt it. The 1st and 2nd rings are solid, the 3rd is the oil scraper, which does include a mesh type of centre section. Irrespective of what it might be, this has all the hall marks of an engine out and rebuild job. Smashed up plugs is never a good sign.
« Last Edit: 05 December, 2024, 08:20:16 AM by LCR1967 » Logged
« Reply #4 on: 05 December, 2024, 07:57:48 AM »
Probably a dropped valve. Or valve head snapped off. This is not as rare as you think on engines that have been standing.
julian67
« Reply #5 on: 05 December, 2024, 08:48:45 AM »
Thanks Tim. Will know today as mechanic is removing the head.
Page created in 0.062 seconds with 20 queries.
