30 December, 2024, 05:46:18 PM
Welcome,
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News
forum.admin@lanciamc.co.uk
events@lanciamc.co.uk
- To Join the club go to
Home
Help
Search
Calendar
Register
Lancia Motor Club
Model Technical and Interest
Fulvia
Seat back refoaming
Pages: [
1
Go Down
« previous
next »
Author
Topic: Seat back refoaming (Read 430 times)
HBG
Seat back refoaming
on:
06 December, 2024, 09:33:22 PM »
Hi folks.
Anyone here with experience of opening up seat backs and improving the foam?
I've changed the seat base foam but find the backs offer little support which isn't great on a long journey. Ideally I'd like to remove the cover and fit new centre and bolster foams of a firm enough type, bit what type and how to do it?
nthomas1
Re: Seat back refoaming
Reply #1 on:
10 December, 2024, 08:31:43 PM »
I guess the three questions are: what type of foam to use for the padding, how to shape it, and how to remove and reattach the fabric from its supports to enable replacement of existing foam.
Polyurethane foam seems to be the favoured padding material. Available from companies like eFoam.co.uk. I have heard of one Berlina owner using memory foam.
Ideally the foam would be cut (or moulded) to shape like the bases that Giuseppe Rampello had made up. Though I imagine that blocks of foam would not be that easy to cut/carve to shape in a diy environment. The alternative would be to use thin layers of foam, stacked in stepped fashion to approximate the curves.
With regard to removing the fabric of the seat, that looks trickier with the two-part seat back than with the one part seat base. You could unpick the stitching and carefully peel back the fabric to see how easy it would be to remove. But after re-padding the edges would need to be re-stitched. With the seat base it was possible to glue the fabric after folding it over the bottom of the metal base. Not so easy with the backs.
Two other thoughts: maybe take one seat back to a local upholsterer (preferably an automotive one) for a quote, though I know that, like me, you like to attempt jobs yourself. Secondly, it could be worth posting your question in the General Chat section of the forum to see if owners of models other than Fulvia can provide any suggestions.
Norm Thomas
Ormskirk, Lancashire
Own:
1973 Fulvia S2 Coupe
HBG
Reply #2 on:
11 December, 2024, 06:51:48 AM »
Hi Norm
I've been searching the net for answers to some of those questions.
My seat covers are just about serviceable so long as I keep up with repairs as and when required but the seat back foam has to be improved.
There seem to be many different grades of foam available but no info as to which grade would most closely mimic the original. From there I could choose to go firmer if required. I'd consider shaping the foam a challenge!
Does the seat back come off when unscrewed from the chrome side plates? If so, I might take a seat off and have a look at how it dismantles.
I'm also interested in finding a supplier for the edge trim that retains the seat base cover. It's a sort of cardboard that's sewn to the cover that tucks under the seat. And a male/ female trim that holds the headrest cover closed.
LCR1967
Reply #3 on:
11 December, 2024, 01:46:04 PM »
Does anyone know the construction of the seat back foam?
I recently replaced the rear seat base, with the intention of also addressing the foam. Once the covers were off and the foam removed, the foam construction was like the fronts, in that they had many pockets. So I experimented with just plugging the pockets with new foam, as opposed to cutting it in half and gluing in place new foam. In the end I am happy with the result. The donor foam was quite stiff and coupled with the original has resulted in a seat base that is now firmer than previous.
Perhaps you can give this a go.
Pages: [
1
Go Up
« previous
next »
Please select a destination:
General
=> About the LMC Forum
=> General Chat
=> Competition Information
=> Events 2024
=> Events 2025
=> Local Events
=> LMC Legends
=> Links
=> Pre-Lambda
=> Lambda
=> DiLambda
=> Artena and Astura
=> Augusta
=> Aurelia
=> Appia
=> Flaminia
=> Flavia
=> Fulvia
=> Stratos
=> Beta and Montecarlo
=> Gamma
=> Delta and Prisma
=> Ypsilon, Musa and Y10
=> Kappa
=> Thesis
=> Delta (2008-)
=> Commercial Vehicles
=> Other Lancia Models
Buy, Sell and Search
=> Members' cars for sale
=> Lancia vehicles for sale
=> Lancia vehicles required
=> Spares for sale
=> Spares required
Events Archive
=> Events 2011
=> Events 2012
=> Events 2013
=> Events 2014
=> Events 2015
=> Events 2016
=> Events 2017
=> Events 2018
=> Events 2019
=> Events 2020
=> Events 2021
=> Events 2022
=> Events 2023
Loading...
