Author Topic: Sump oil pickup cap screws  (Read 1394 times)
jonamery
  • Member
« on: 30 December, 2024, 08:47:26 PM »
Hello,
Long shot… I’ve misplaced the 2 sets of 2 cap screws that attach the oil pickup to the crankcase.
I don’t suppose anyone knows their length? They are m6 x 1 thread.
Also, if anyone has a sump available with the drain hole at the rear rather than the middle and its pickup, I’d be interested.
Many thanks,
Jon
« Last Edit: 30 December, 2024, 09:56:35 PM by jonamery »
Spider2
  • Megaposter
Re: Sump oil pickup cap screws
« Reply #1 on: 31 December, 2024, 02:04:11 PM »
I have a set of those cap screws from when I dismantled a 302 engine last year. I'll try to locate the baggie i put them in. Also have a sump in very good condition with no broken fins. Will check out where the plug is.
jonamery
  • Member
« Reply #2 on: 31 December, 2024, 08:46:23 PM »
Many thanks, much appreciated! I think the ones that attach on the bracket at the end of the tube are shorter..
  • Press Officer
  • Permanent resident
« Reply #3 on: 01 January, 2025, 09:26:34 AM »
The bracket set screws also have a shorter head.
Spider2
  • Megaposter
« Reply #4 on: 04 January, 2025, 12:24:26 PM »
Sorry but my spare sump has the oil drain in the middle. I have a spare strainer and pick up if you need one.
jonamery
  • Member
« Reply #5 on: 04 January, 2025, 07:42:06 PM »
I sent you an email, still maybe interested as the sump I have has damage to the fins.
« Reply #6 on: 05 January, 2025, 11:51:10 AM »
Did any model of Fulvia have the sump other than in the middle of the sump?
Both my series 1 Coupe and My 2c Berlina both have a central drain plug.
Never found it a problem myself?
8227 8)
  • Press Officer
« Reply #7 on: 05 January, 2025, 12:05:57 PM »
8227 8)
Earlier Fanalone 1.5HF had a larger (sand cast) sump with the drain to the rear. Fulvia 3 saw the introduction of a different (investment cast) sump from standard with marginally more capacity and a drain plug at the rear.
  • Megaposter
« Reply #8 on: 05 January, 2025, 03:23:06 PM »
The S3 sump with the plug at the back originates from the contemparary FIAT 127.
« Reply #9 on: 07 January, 2025, 08:43:46 AM »
8227 8)
Thanks Tim,
New to me !
8827 8)
