Author Topic: Oil drain plug  (Read 1100 times)
cbudden
  • Member
Oil drain plug
« on: 24 January, 2025, 06:29:57 PM »
Good evening, Could anyone advise me of the dimensions of, or better still, a supplier, for the oil drain plug on the underside of the crankcase. I have measured the hole with cheap digital calipers and I don’t arrive at a sensible number in metric or imperial! Any help gratefully received.
Raahauge
  • Senior Member
Re: Oil drain plug
« Reply #1 on: 24 January, 2025, 08:59:02 PM »
I probably have a spare, I will look over the weekend. If no spare I can certainly measure it for you.
Regards
Mike
cbudden
  • Member
Re: Oil drain plug
« Reply #2 on: 24 January, 2025, 09:03:51 PM »
That would be great, many thanks. I spent a good while on the internet trying to find something but to no avail. I am just about to start rebuilding an engine I bought as several boxes of bits and have just had repairs to the block and head done. It’s all new to me but interesting!
Kari
  • Senior Member
Re: Oil drain plug
« Reply #3 on: 26 January, 2025, 10:33:09 AM »
Hello Chris,
The tread is M30 X 1,5.  the Hex for the tool is 22 mm. Instead of a copper gasket, I use an O-ring as seal.
Karl
cbudden
  • Member
Re: Oil drain plug
« Reply #4 on: 26 January, 2025, 11:08:35 AM »
Thanks both, very helpful. In case you are wondering I recently bought a project 1935 factory cabriolet (type 34). So expect to hear more from me!!
Kari
  • Senior Member
Re: Oil drain plug
« Reply #5 on: 26 January, 2025, 04:18:40 PM »
We are wondering! It would be much appeciated if you can tell us the story of your Augusta project, perhaps a few pictures. Thanks very much.
Karl
