Author Topic: Carello headlight refurbishment  (Read 475 times)
Simon B
  • Member
« on: 18 March, 2025, 11:34:26 PM »
Has anyone had any success separating Carello headlight glass from a rusty reflector and replacing the reflector with one from a readily available modern unit?  I thought it worth a try but the sealant/ adhesive around my Carello lights seems to be rock hard and not easy to shift compared to modern replacements which use silicone or similar.
  • Megaposter
Re: Carello headlight refurbishment
« Reply #1 on: 19 March, 2025, 08:05:49 AM »
Apparently it is necessary to submerge the glass fro several days in cellulose thinner.
Simon B
  • Member
« Reply #2 on: 19 March, 2025, 09:08:19 AM »
Thanks Nistri, I’ll give that a try and report back
andyps
  • Megaposter
« Reply #3 on: 26 March, 2025, 12:38:18 PM »
I separated one of the light units for my Sport - gently heated it in the oven which I'd seen suggested as a way to soften the fixing. Can't remember what temperature I got it to, too hot to hold, but not massively high and then I managed to get it apart. Not an enjoyable task!!
Simon B
  • Member
« Reply #4 on: 27 March, 2025, 10:03:21 AM »
Thanks Andy and Nistri, the cellulose didn’t work, several days with the glass submerged and the seal remained unaffected, just wrinkling the lacquer on outside of the lamp bowl.
As I only want the glass from the old lamps, I took an angle grinder to the metal bowl on another lamp. I ground most of the way through the bowl and finished off with a small cutting disc in a dremel until just breaking through. Easy enough to peel the metal rim away and the glass and plastic like seal came away easily.
I can see that the oven technique working, although difficult to execute. I think I’ll stick to the brutal angle grinder technique on the others assuming I can find suitable modern lamp bowls to fit the old glass. The plan is to break the glass out of them.
andyps
  • Megaposter
« Reply #5 on: 30 March, 2025, 02:24:37 PM »
Good to know you've been successful with it. For the Sport the metal backs are as rare as the glass so I didn't want to cause damage. I needed to refinish the inside due to rust and was surprisingly successful with a mirror like paint.
