The Automobilia book "Lancia Thema 8.32" printed 1986 ISBN 88-85058-50-7, States.
"Derived directly from the engine of the "old 308 sport coupe:
90 Degree V8 with 2927cc (81x71mm) and a compression ratio of 10.5:1. Top power 215 HP at 6750 rpm and a maximum torque of 29mkg at 4500 rpm.
Valves, four per cylinder, driven by four overhead camshafts, two per bank. Bosch KE3 Jetronic electronically controlled mechanical fuel injection specially designed for this engine. Marelli microplex electronic ignition.
It is thus structurally identical to the 308, but the 8.32's engine has undergone some modifications to adapt it to the "softer" character of the sedan. The crankshaft now features connecting rods offset 90 deg to each other (a "cross" shaft rather than the 180 deg ("flat " shaft) as usually found in Ferrari engines. This creates a reciprocating relationship between the power strokes (firing order) of the two cylinder banks, making for more fluid operation and eliminating the nervousness typical of sporty engines".
Further.
" The Thema's five speed gearbox has been partially modified, in the primary shaft and synchronizer bearings, fith gear is "Multiplied", i.e. with the drive ratio below 1: it is a drive gear, so that top speed is reached in this gear."
"The friction now mounts a 230mm disk, and the control has automatic play recovery according to disk wear"
Very good quality book even though only 84 pages.
8227
