30 November, 2024, 12:03:32 PM *
Pages: 1 ... 11 12 13 14 15 [16] 17 18 19 20 21 ... 24   Go Down
Author Topic: ardea pickup.........THING!  (Read 157826 times)
0 Members and 13 Guests are viewing this topic.
chugga boom
Non-LMC Seller
« Reply #225 on: 24 January, 2010, 09:16:16 PM »
if all else fails i'll get a crown wheel and pinion made, my dad recons about a thousand pounds to have them made as a 1 off, i cant really see any demand for a batch to be made  Cheesy, i would prefere if i didn't have to spend that kind of money on an axle so fingers crossed the aprilia bits will fit  Roll Eyes
1935 augusta lusso (chugga)
1935 belna saloon
1935 augusta lusso
1938 ardenne
1939 aprilia lusso
1958 appia s2
1963 appia s3
195? appia camioncino
1972 fulvia 1600HF
1976 fulvia coupe
« Reply #226 on: 25 January, 2010, 09:10:15 AM »
To make replicas of the Austin 7 single seaters its common practice (as much as such things ever can be) to chop an axle up and remake with an offset such that the prop runs down the side rather than under the seat.   The short half shaft is easy enough, and the long half shaft is cut and the extra length put in with sleeve joints.
It sounds drastic, is going to depend on the exact shape and weldability of the case, maybe you'd make up the longer half shafts from scratch or find the Appia ones fitted...
Something to ponder before writing a cheque for a grand.
David
chugga boom
Non-LMC Seller
« Reply #227 on: 25 January, 2010, 09:27:23 AM »
hmmm maybe, i'll bare it in mind, axle is being cleaned at the moment ready to strip, i'm really hoping the aprilia crownwheel etc will fit
1935 belna saloon
1935 augusta lusso
1938 ardenne
1939 aprilia lusso
1958 appia s2
1963 appia s3
1972 fulvia 1600HF
1976 fulvia coupe
chugga boom
Non-LMC Seller
« Reply #228 on: 27 January, 2010, 08:26:55 PM »
work has commenced on striping the rear axle, we had to make a puller to remove the half shafts but everything else was straight forward enough, my dad now has the diff and is currently dismantling a standard irs type aprilia diff to hopefully swap the crown wheel and pinion over, we powerwashed the axle complete after a good soaking with alloy wheel cleaner ( works a treat on rust grime and alloy diffs and drums) dismantled all the brakes which (1st impressions) look in really good condition, all the nuts and bolts are soaking in neat alloy wheel cleaner over night to make them like new again,
1935 belna saloon
1935 augusta lusso
1938 ardenne
1939 aprilia lusso
1958 appia s2
1963 appia s3
1972 fulvia 1600HF
1976 fulvia coupe
chugga boom
Non-LMC Seller
« Reply #229 on: 27 January, 2010, 08:28:42 PM »
more........
1935 belna saloon
1935 augusta lusso
1938 ardenne
1939 aprilia lusso
1958 appia s2
1963 appia s3
1972 fulvia 1600HF
1976 fulvia coupe
« Reply #230 on: 27 January, 2010, 08:37:48 PM »
....fingers crossed....
« Reply #231 on: 27 January, 2010, 10:40:22 PM »
Looking good, hope everything swaps over ok Grin I take it the oil needed changing Wink
chugga boom
Non-LMC Seller
« Reply #232 on: 27 January, 2010, 11:13:01 PM »
the oil was suprisingly clean, i've re-used it, recycled been green whatever you want to call it........... it provided about 10 mins worth of heating in the unit  Cheesy
1935 belna saloon
1935 augusta lusso
1938 ardenne
1939 aprilia lusso
1958 appia s2
1963 appia s3
1972 fulvia 1600HF
1976 fulvia coupe
Sliding Pillar
« Reply #233 on: 28 January, 2010, 06:37:30 PM »
James. if you are using old engine oil for heating I have about 10, 25Litre drums of old engine oil that you are welcome to. There used to be a local garage I gave it to, but that is now a housing estate! and the local recycling center get a bit funny if you try to recycle more than 5l at a time!  Ade.
1955 Aurelia
1961 Lamborghini
chugga boom
Non-LMC Seller
« Reply #234 on: 28 January, 2010, 10:17:04 PM »
Thanks ade i always collect it though the year and burn it this time of year so if its a problem for you to get rid of send it my way  Grin we will have to sort something out for when your either up hear or i'm down near you to collect it , 10x25lr drums is about a weeks heating so well worth me having, thanks for the offer and i'll definatly take you up on it , james
1935 belna saloon
1935 augusta lusso
1938 ardenne
1939 aprilia lusso
1958 appia s2
1963 appia s3
1972 fulvia 1600HF
1976 fulvia coupe
chugga boom
Non-LMC Seller
« Reply #235 on: 31 January, 2010, 07:05:55 PM »
done a little more this weekend, rubbed down the rear inner wings , spray sealed them, re etched them, then colour (atlast !!), also finished cleaning the rear axle casing ready for paint and then painted it into colour, the plan is to refit the diff then fit the axle to the car, then fit the shafts brakes etc so i can tighten everything propperly as it goes together, anyway here's some pics and of the products i use
1935 belna saloon
1935 augusta lusso
1938 ardenne
1939 aprilia lusso
1958 appia s2
1963 appia s3
1972 fulvia 1600HF
1976 fulvia coupe
chugga boom
Non-LMC Seller
« Reply #236 on: 31 January, 2010, 07:07:48 PM »
more...............
1935 belna saloon
1935 augusta lusso
1938 ardenne
1939 aprilia lusso
1958 appia s2
1963 appia s3
1972 fulvia 1600HF
1976 fulvia coupe
LanciAlan
« Reply #237 on: 31 January, 2010, 11:25:03 PM »
Whats the black paint you're using on the axle and do you use anything under it?
In the past I've just rotary wire-brushed various bits of suspension hardware like this and put Hammerite on but it always seems to rust through in service, even when I apply 2 coats with a brush.
Alan Murphy
Lancias that begin with "F" ... and affordable variants beginning with "Z" and "P" ..... and now with added "Y"!
chugga boom
Non-LMC Seller
« Reply #238 on: 01 February, 2010, 11:32:24 AM »
its good old black 2pack, i used a di grinder with sanding attachement to clean it up 1st, then etch prima, then 2k prima then gloss, i do it in a way thats called "wet on wet" which meens as the 1st paint is just dry "to touch" you put the second paint on without rubbing down between then the same again when the prima is just about dry or skinned over straight on with the black, as the paints haven't fully cured the adhease to each other with no need to rub down between coats, this method is no use whatsoever on body work but works a treat on things like the axle and under the arches also saves alot of time and effort, i've also had excellent results with dulux bare metal prima >undercoat >gloss on chassis and axles in the past and the rust doesn't seem to come back, 2k has a slightly better shine to it and stays shiney longer however the dulux is more durable and less likely to chip off as it doesn't cure hard like 2k, hammerite if i'm honest i've never really liked , never found it to last as well as the other 2 ways that i've mentioned , hope this helps  Grin
1935 belna saloon
1935 augusta lusso
1938 ardenne
1939 aprilia lusso
1958 appia s2
1963 appia s3
1972 fulvia 1600HF
1976 fulvia coupe
LanciAlan
« Reply #239 on: 01 February, 2010, 04:15:57 PM »
Thanks Chugga
2 pack is beyond my technical reach but I do agree with you on how underwhelmed I have been with the properties of Hammer5hite  - probably one of those products that is deliberately targeted only at DIY people like me 'cos the trade has a better answer that is either cheaper, better or, as in your case, more dangerous. I will revert to good old Dulux type stuff in future.
I have been generally restraining myself on your pickup threads of late because I feel a bit responsible for the latest affliction .... even the added humor of the photos from the "Where's Warby?" thread cannot adequately compensate for how shocked and horrified I felt when I saw the first pictures of it over Christmas. So far I have really just been trying to figure out how to deal with these emotions and my heavy guilt before venturing any opinion as such on the whole situation.
In the meantime however, I will leave you with the words "broderie" and "gruyere" and the following images and a sincere apology.
Alan
« Last Edit: 01 February, 2010, 04:18:32 PM by LanciAlan » Logged
Alan Murphy
Pages: 1 ... 11 12 13 14 15 [16] 17 18 19 20 21 ... 24   Go Up
Page created in 0.063 seconds with 21 queries.
