I added an electric pump to my 2c a couple of years ago, as I was fed up with churning the engine over so much, it was well worth doing.
After i've switched the pump on and the warning light has stopped flickering, I turn the pump off, turn the engine over while at the same time operating the choke, and she fires instantly, what bliss
no more mechanical torture! only problem is that this doesn't cure any leaks at the mechanical pump, but it certainly makes life easier.
8227
