21 December, 2024, 12:04:57 PM *
Author Topic: Flaminia GT bodywork  (Read 5790 times)
dannels
« on: 20 January, 2009, 01:24:00 PM »
Hi All,
I'm restoring my FlaminiaGT - see here for detail http://www.flaminiagt.co.uk
..and have a question - there is a gap between the inner steel wheel arch and the outer aluminium wing. Does anyone know what was originally between the two - was it a rubber seal or some other material? Does anyone know where I can find something that will give a good seal and keep the steel away from the outer wing?
Dave
Alwyn Price
« Reply #1 on: 20 January, 2009, 07:34:20 PM »
Hi All,
Dave
As a retired Water Engineer, I can recommend two Denso products.  Easy to use and virtually foolproof.  Coat both surfaces with Denso paste, which is like grease, and pack any gaps with Denso filler.  I'm not sure of the current correct name but 30 years ago we called it "monkey muck" when you see it you'll know why. Fill any gap by rolling the filler into a sausage and push home with a wooden peg tapping with a hammer, if neccessary
Sliding Pillar
« Reply #2 on: 20 January, 2009, 08:03:17 PM »
Originally it would have been a sponge rubber seal. (not the best solution as it held water!!)  You can get suitable seals from Paul Beck Vintage supplies or Woolies (No not Woolworths!).
1955 Aurelia
1961 Lamborghini
dannels
« Reply #3 on: 28 January, 2009, 12:56:31 PM »
Thanks guys - having asked around I think I going for a combination of rubber strip and sealant to bond to the inner/outer arches.
I'll take a look at Paul Beck - as I don't know them - thanks for the tip!
Sliding Pillar
« Reply #4 on: 28 January, 2009, 07:59:46 PM »
I have also found another company that specialise in seals of all descriptions, seals+direct I managed to get some seals for the Aurelia Pininfarina hood that were not available anywhere else.
1955 Aurelia
1961 Lamborghini
