21 December, 2024, 01:54:47 PM *
Author Topic: 8 to 16 valve conversion  (Read 4729 times)
« on: 20 January, 2009, 03:14:58 PM »
The Boy has an 8 valve 1991/2 Integrale with poor oil pressure.  I have a 16 valve Thema Turbo engine sitting in the shed.  How to we transplant the 16v into the Integrale?  We have the brain, does it just plug into the socket?
The engine specs for the 16v Integrale and Thema seem to be the same.
All advice eagerly awaited.
Chris5090
« Reply #1 on: 20 January, 2009, 10:26:00 PM »
Now i've never done this job but these are a few things i would think would be different.
The wiring loom will be different.
The Engine mounts will be different
All the pipework would have to come from a 16v Integrale
Are the Radiators (Oil & Water) and Intercooler the same?
Gear Ratios / Clutch & flywheel (the box will bolt on (the bolt pattern is the same))
All the associated brackets etc
Also don't forget that you should really change the front suspension to allow for the different weights
I don't want to put a spanner in the works, but for the amount of work and cost i'd think it would be easier to source another 8v and drop it straight in?
Anyone with more knowledge than me may know better though..... Wink
Neil Lewis
« Reply #2 on: 21 January, 2009, 10:29:14 PM »
I guess, since this 8-valve is from 1991/92, its actually one of the Evo bodied cars with the 8-valve engine fitted.  I know these were fitted to Swis cars and had a catalyst fitted but maybe someone else can spread a bit more light on the subject.
Personally, and being an 8-valve owner, I wouldn't swap my engine for a 16-valve unless it was from an Evo.  My car is so much more usable than any of the 16-valve (not Evo) cars I've driven.  However, I don't believe that the job would be too difficult especially as this car will have the raised Evo bonnet.  The engine sensors are mostly in the same places so the wiring would only need minor mods.  But you will need all the correct 8-valve hoses cos the ones from the Thema definitely won't fit!
Neil
« Reply #3 on: 23 January, 2009, 03:05:43 PM »
I am surprised by the comments as I understood that the only differences between the two engines are the number of valves and the manifolds internally.  We'll have to have a good look at the two engines and take some measurements. The blocks are certainly the same.  Of course, there may be a simple explanation for the poor oil pressure reading which is surprising as the engine has only done some 70,000 miles according to the odometer...
Page created in 0.045 seconds with 21 queries.
