22 December, 2024, 05:57:52 AM *
Author Topic: axle stands to front of car  (Read 4310 times)
bill
« on: 13 March, 2009, 05:07:33 PM »
hello everyone, I need some advise on where to place the axle stands. the work I am going to carry out, welding to the wheel arch and would like to start and overhaul the brakes.
at present I have the rear of the car on axle stands and the front on ramps. my question is when the front wheel is removed where would be a safe place to put an axle stand ? to support the car.
thank you.
Bill.
ps. this is the start of many questions.
Richard Fridd
« Reply #1 on: 13 March, 2009, 07:24:14 PM »
Hi Bill,my MOT man always uses supports under the subframe centre cross member of my S1 sport to check front suspension on full droop.I have also known jacks/axle stands to be used beneath front lower wishbones. richard
ColinMarr
« Reply #2 on: 13 March, 2009, 08:03:11 PM »
Bill,
I agree with Richard. When I need to raise the front of my car I use a trolley jack under the centre of the front cross member and lift it to the limit, then I put axle-stands under the sub-frame at the point where the inner ends of the wishbones are mounted. If I need to get it higher, I put the trolley-jack on wooden planks and do the whole thing once more. Take care!
Colin
An afterthought: When you do this for the first time, and if you have any worries about the structural integrity of your car, do the initial jacking from the front cross-member with great care! If you hear ominous creaks and groans – stop and think again! You might be better off jacking equally from each side further back down the sub-frame.
« Last Edit: 13 March, 2009, 08:17:38 PM by ColinMarr » Logged
chugga boom
Non-LMC Seller
« Reply #3 on: 13 March, 2009, 10:37:24 PM »
whenever i have done welding around the front end of a fulvia i have always supported all 4 corners of the subframe to make sure NOTHING moves, even on a good fulvia because the engine is so far forward , if supported at the rear of the subframe the engine tends to make the front of the subframe droop and if supported at the front it put stress on the a post area, i normally put axle stands on the rear out riggers and a trolley or bottle jack under the jacking point on the front of the subframe to take up the load, hope this helps jp
1935 augusta lusso (chugga)
1935 belna saloon
1935 augusta lusso
1938 ardenne
1939 aprilia lusso
1958 appia s2
1963 appia s3
195? appia camioncino
1972 fulvia 1600HF
1976 fulvia coupe
rogerelias
MY 1600HF IN HEARTBEAT GARAGE
« Reply #4 on: 14 March, 2009, 10:48:15 AM »
And if your sub frames a bit dodgy, i have 2 that i will be selling soon both very good condition. Cool
FULVIA 1600HF LUSSO
1958 VELOCETTE MAC
Triumph Bonneville t120v 1972
1968 MGC ROADSTER
1958 Series 2 Appia berlina
Page created in 0.04 seconds with 20 queries.
