21 December, 2024, 04:14:07 PM
Welcome,
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News
forum.admin@lanciamc.co.uk
events@lanciamc.co.uk
- To Join the club go to
Home
Help
Search
Calendar
Register
Lancia Motor Club
Model Technical and Interest
Fulvia
Started welding.
Pages: [
1
Go Down
« previous
next »
Author
Topic: Started welding. (Read 4010 times)
bill
Started welding.
on:
06 April, 2009, 07:45:21 PM »
Hello, finally started the welding on the car, seems to be coming along ok, up to now.
A couple of questions, while the car is up on axle stands I would like to check the braking, is it possible to buy the rubber brake hoses going to the front caliper? can anyone tell me why there are 2 bleed nipples and 2 rubber hoses. I would appreciate any advice anyone can give me on the braking system.
Thank you very much.
Bill.
Re: Started welding.
Reply #1 on:
07 April, 2009, 07:59:54 AM »
First, I would advise you to get a CD with the Fulvia workshop manual. The viva-lancia.com site sells them cheaply and they are useful for servicing and repairs. Second, the caliper braking system has two circuits with separate inflow and bleed lines. Note that the length of the rubber hoses is actually different: fitting them wrongly may create problems when turning the steering full lock.
To overhaul calipers, do not split them. Use compressed air through the rubber hoses to eject the plungers after placing a wooden wedge in between them.
Good luck, Andrea
Jai Sharma
Reply #2 on:
07 April, 2009, 12:50:35 PM »
Just a small bit of extra info to add to Andrea's detailed explanation, the hoses are (or at least used to be) available from Omicron. You can also get goodrich type braided hoses which to my mind are a better solution and not much more cost, although I guess you will want to replace them all if you go down that route.
I have also found, if you don't have compressed air (we are short of air down here in Essex), that you can use the hydraulic pressure in the system to push the pistons sifficiently far out that you can then pull them out by hand. To do this take the pads out and just use a very thin piece of wood in place of the pads (in fact I had some pads with only the backing plate left for this purpose) to stop the pistons coming out completely, then bolt the calliper back on the hub. It is worth doing both sides at once because otherwise you have to refill the reservoir and bleed etc to get enough pressure to do the other side.
Good luck!
bill
Reply #3 on:
07 April, 2009, 04:20:32 PM »
Thank you for the replies, I had a look on ebay for the brake hoses they have series2 would these be ok. for series 3? I will be renewing the brake fluid and all the rubber hoses on the front, one thing you may be able to help me with.
The brake fluid reservoir is full, but I have no brake pedal what so ever. once again i really appreciate your advise.
All the best.
Bill.
ncundy
Reply #4 on:
07 April, 2009, 04:50:43 PM »
Air lock in the pipes would be the first thing to check otherwise, if there is no obvious leak then it is probable that the master cylinder is leaking internally or the end seal is leaking and the fluid has deposited itself into the servo.
Jai Sharma
Reply #5 on:
09 April, 2009, 07:45:56 AM »
S2 and S3 pipes are the same by the way
Pages: [
1
Go Up
« previous
next »
Please select a destination:
General
=> About the LMC Forum
=> General Chat
=> Competition Information
=> Events 2024
=> Events 2025
=> Local Events
=> LMC Legends
=> Links
=> Pre-Lambda
=> Lambda
=> DiLambda
=> Artena and Astura
=> Augusta
=> Aurelia
=> Appia
=> Flaminia
=> Flavia
=> Fulvia
=> Stratos
=> Beta and Montecarlo
=> Gamma
=> Delta and Prisma
=> Ypsilon, Musa and Y10
=> Kappa
=> Thesis
=> Delta (2008-)
=> Commercial Vehicles
=> Other Lancia Models
Buy, Sell and Search
=> Members' cars for sale
=> Lancia vehicles for sale
=> Lancia vehicles required
=> Spares for sale
=> Spares required
Events Archive
=> Events 2011
=> Events 2012
=> Events 2013
=> Events 2014
=> Events 2015
=> Events 2016
=> Events 2017
=> Events 2018
=> Events 2019
=> Events 2020
=> Events 2021
=> Events 2022
=> Events 2023
Loading...
