23 November, 2024, 03:16:03 PM *
Author Topic: Trevi timing belt  (Read 3658 times)
Thotos
Theo Kyriacou
« on: 21 April, 2009, 11:03:15 AM »
Having become a Trevi owner just a couple of days ago, here's my first question to show my ignorance. Which timing belt does the 2 litre Trevi need? I thought it should be the same as the 2 litre twin cam Fiats (131, 132 etc) but it seems not. I am confused...  Undecided
Theo Kyriacou
Kevin MacBride
« Reply #1 on: 21 April, 2009, 02:27:50 PM »
Beta 2.0 should be 4201739 same as 131 etc. Trevi should also be the same. Ritmo/Strada 2.0 also is the same.
2000 sedan
Fiat Multipla
Fiat Cinquecento
HF_Dave
« Reply #2 on: 21 April, 2009, 07:22:07 PM »
I had many Betas in my day,
The belts were the same as the 2.0 fiat twin cam as far as I can rember
the 1.6 belt is 2 teeth shorter as I found out many years ago with sweat rolling down my brow
trying to make it fit !!!
Check the condition of the tensioner bearing, there's no point in changing the belt if it jams
you'l be picking bits of valve out of your exhaust,
Good luck with the car
My Current Cars:
1991 Thema station wagon
1989 Thema 16v
2011 Lancia Delta 3
1977 Beta sedan 2000
1975 Fulvia S3 1.3
1973 Flavia HF 2000 Coupe
1972 Fulvia S2 1.3
1989 Thema 8.32
**Other Makes**
2018 Alfa Giulia
1999 Alfa 156
2009 Fiat Du
Thotos
Theo Kyriacou
« Reply #3 on: 22 April, 2009, 10:11:58 AM »
Thanks for the info and advice guys. Should be my weekend job. I was having a look last night and there's not a lot of room at the front of the engine in the transverse installation in the Trevi. Doesn't look as easy as changing the belt on my Fiat 131.  Undecided
Had a lot of fun trying to get the lights to work last night. Ended up being a bad connection in the fuse box so I took it off, took it apart and re-soldered the offending pin. Works fine now but it was 1:30 in the morning by the time I finished.  Roll Eyes And just to make it all feel worthwhile I used the car to get to work today  Grin
« Last Edit: 22 April, 2009, 10:13:29 AM by Thotos » Logged
Theo Kyriacou
