23 December, 2024, 08:35:05 PM
Welcome,
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News
forum.admin@lanciamc.co.uk
events@lanciamc.co.uk
- To Join the club go to
Home
Help
Search
Calendar
Register
Lancia Motor Club
Buy, Sell and Search
Spares required
Hydragas / Hydrolastic pump
Pages: [
1
Go Down
« previous
next »
Author
Topic: Hydragas / Hydrolastic pump (Read 6141 times)
Neil Lewis
on:
12 June, 2009, 09:23:39 PM »
I know it's a bit off topic but does anyone here have a hydragas/hydrolastic pump I could buy or borrow. I have to take the suspension off my Rover 100 (Metro) and it can't be done without letting all the fluid out and afterwards pumping it back up again.
Many local garages have these things but that means driving the car with no fluid in the system, ie, on the bump stops. So it would be much more convenient to do it myself.
Neil Lewis
Re: Hydragas / Hydrolastic pump
Reply #1 on:
17 June, 2009, 11:07:30 PM »
I've now done a deal with my local garage. They have an original BMC Hydravac pump and, if I can repair it, I can use it whenever I like. So I have this device in my shed ready to strip down. Wish me luck.
ian
Reply #2 on:
19 June, 2009, 10:50:17 PM »
I could also do with one as well, the MG F is quite a bit lower than it should be!
Good luck on the rebuild
Neil Lewis
Reply #3 on:
21 June, 2009, 11:29:14 PM »
The pump up side appears to be working correctly bu the vacuum side was seized solid. I stripped it down this afternoon and found it's a masterpiece of fifties/sixties design with a bent meta frame containing all the gubbins with sheet steel panel self-tappered on. I managed to get the brass vacuum pump apart and it looks like it will be OK with just a good clean, ie, no new seals required. The reason it was seized is the copius amounts of grease put in, presumably to keep it free, had absorbed water and rusted the pump shaft.
Even when I've fixed it, it will still belong to the "garage" but the deal was that I could borrow it whenever I wanted. I have a gallon of hydragas fluid so I might be able to pump up your "F". Where are you located?
ian
Reply #4 on:
21 June, 2009, 11:40:17 PM »
Unfortunately Cornwall Neil, but I do occasionally get up to Bath and Swindon area, Any excuse for a drive
Neil Lewis
Reply #5 on:
22 June, 2009, 10:47:50 PM »
Well Swindon is only 30 miles from me on the west side of Oxford. I travel there quite often and it's an easy journet so long as not at rush hour.
Anyway, let me fix the pump first, then we can see.
ian
Reply #6 on:
11 August, 2009, 08:14:32 PM »
Neil, any luck on the Hydragas pump?
Pages: [
1
Go Up
« previous
next »
Please select a destination:
General
=> About the LMC Forum
=> General Chat
=> Competition Information
=> Events 2024
=> Events 2025
=> Local Events
=> LMC Legends
=> Links
Model Technical and Interest
=> Pre-Lambda
=> Lambda
=> DiLambda
=> Artena and Astura
=> Augusta
=> Aurelia
=> Appia
=> Flaminia
=> Flavia
=> Fulvia
=> Stratos
=> Beta and Montecarlo
=> Gamma
=> Delta and Prisma
=> Ypsilon, Musa and Y10
=> Kappa
=> Thesis
=> Delta (2008-)
=> Commercial Vehicles
=> Other Lancia Models
=> Members' cars for sale
=> Lancia vehicles for sale
=> Lancia vehicles required
=> Spares for sale
=> Spares required
Events Archive
=> Events 2011
=> Events 2012
=> Events 2013
=> Events 2014
=> Events 2015
=> Events 2016
=> Events 2017
=> Events 2018
=> Events 2019
=> Events 2020
=> Events 2021
=> Events 2022
=> Events 2023
Loading...
