27 December, 2024, 02:21:05 AM
Welcome,
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News
forum.admin@lanciamc.co.uk
events@lanciamc.co.uk
- To Join the club go to
Home
Help
Search
Calendar
Register
Model Technical and Interest
Fulvia
long travel
Pages: [
1
Go Down
« previous
next »
Author
Topic: long travel (Read 3434 times)
bill
long travel
on:
27 June, 2009, 02:48:27 PM »
hi,I bought myself the guson ezibleed what a handy piece of kit, had a small problem trying to get a good seal on the filler cap. bleed the brakes twice just to make sure, my querie is the travel on the brake pedal, it goes quite a way down is this normal if not any ideas what the problem may be? I tried the car down the street and it seemed to pull up alright and I can the servo working.
look forward to hearing your replies.
bill.
would this be a fail on the test?
ColinMarr
Re: long travel
Reply #1 on:
27 June, 2009, 05:10:14 PM »
Bill,
If you are satisfied that the system is bled properly, the pedal doesn’t pump-up and is not spongy, then it may be that you need to increase the length of the push rod between the pedal and the servo/master cylinder.
Look at the diagram before you start and think it through! You can get access (just!) by kneeling beside the car looking up into the pedals. Remove the split pin that goes sideways through the end piece of the brake push rod and unscrew the plug about two turns. Undo the locking nut that secures the end-piece – pull this sideways off the ball that is fixed to the pedal and undo it say one turn. Put it back on the ball. Screw the plug back in until it just touches the ball. Tighten the lock nut. Refit the split pin and check the ball is not binding on the end piece.
This should give you a shorter pedal and you may need to do it more than once. Beware - if you adjust the push rod so that it is too long the pistons in the master cylinder will not come back far enough and as the system get hot the brakes will bind on!
Colin
bill
Re: long travel
Reply #2 on:
29 June, 2009, 07:50:04 PM »
hi colin, thank you for the in depth reply, I am just going to go round the car once more to check for air in the system. the car has stood for over 3 years so may be I have missed some thing.
thank you once more .
bill.
Re: long travel
Reply #3 on:
29 June, 2009, 09:10:50 PM »
I am still getting the odd bubble from my 1.3S brakes that I rebuilt 4 years ago.
1998 Zeta 21. 12v
bill
Re: long travel
Reply #4 on:
01 July, 2009, 06:01:59 PM »
hi Colin, I have bled the brakes once more and the pedal only goes down around half way lets hope that will be ok. the brakes seem good.
Bill
Pages: [
1
Go Up
« previous
next »
Please select a destination:
General
=> About the LMC Forum
=> General Chat
=> Competition Information
=> Events 2024
=> Events 2025
=> Local Events
=> LMC Legends
=> Links
=> Pre-Lambda
=> Lambda
=> DiLambda
=> Artena and Astura
=> Augusta
=> Aurelia
=> Appia
=> Flaminia
=> Flavia
=> Fulvia
=> Stratos
=> Beta and Montecarlo
=> Gamma
=> Delta and Prisma
=> Ypsilon, Musa and Y10
=> Kappa
=> Thesis
=> Delta (2008-)
=> Commercial Vehicles
=> Other Lancia Models
Buy, Sell and Search
=> Members' cars for sale
=> Lancia vehicles for sale
=> Lancia vehicles required
=> Spares for sale
=> Spares required
Events Archive
=> Events 2011
=> Events 2012
=> Events 2013
=> Events 2014
=> Events 2015
=> Events 2016
=> Events 2017
=> Events 2018
=> Events 2019
=> Events 2020
=> Events 2021
=> Events 2022
=> Events 2023
Loading...
