26 November, 2024, 04:28:53 PM *
Pages: 1 2 3 4 [5] 6 7 8   Go Down
Author Topic: B20 awoken after 46 years  (Read 61920 times)
Kevin MacBride
« Reply #60 on: 25 March, 2012, 12:48:25 AM »
Well, today was a big day. Did a few checks, filled the pot joints with oil, checked water, oil etc. Fired her up, into gear and went for a short spin (very short). About half a mile up a quiet country road, did a 2 point turn and back. All works well...
A few little issues, rad boiled a bit, but on checking after it had cooled down, what I thought was a leak turned out to be an air lock, forcing water out of the overflow. Clutch needs attention as the 'bite'point is just at the end of pedal travel. Gears select with no problems and gearbox is very slick, no noise from 1st gear. I was worried most about the gear selection as the column shift had been dismantled and I only had the worshop manual pictures as a referance.
Even the rad flap thermostat works. The oil pressure guage does not however, I know the pressure is good as I checked using a guage, so thats a job for another day.
I'd like to fit a water temp guage. My own car has one, there being a switch tapped into the top rad pipe assembly. Any ideas as to fitting one ?
Still a lot of work to do, fitting door glass, lamps, dynamo is not connected so I dunno if it works properly or not, plenty of wiring to be sorted as well.
Rear shocks are an issue. The original lever arms are gone, being replaced by shocks. The bushes are well perished, and rattle a bit.
Aiming for a finish date before June, for the annual Terenure Car show, where I've arranged for the car to be pride of place on the main sponsers stand.
2000 sedan
Fiat Multipla
Fiat Cinquecento
« Reply #61 on: 25 March, 2012, 08:47:43 AM »
Even more good news Kevin, great to get to that point and find out things aren't too bad, when is the Terenure show....maybe I'll google it!
« Reply #62 on: 25 March, 2012, 08:51:30 AM »
http://bmwclassicsireland.com/events/terenure-classic-car-show-2012
8th of July on this Kevin, its correct?
Kevin MacBride
« Reply #63 on: 25 March, 2012, 09:45:20 AM »
Yep, thats the one. The Club normally has its own stand, with a good turnout. I've not been to too many of them as they usually clash with racedays, but I'll make an effort for this one.
2000 sedan
Fiat Multipla
Fiat Cinquecento
« Reply #64 on: 25 March, 2012, 10:13:30 AM »
Many other Lancias attend Kevin, might make the 200 mile round trip to go, if weather not Malaysian like!
« Reply #65 on: 25 March, 2012, 04:14:19 PM »
So the first gears were NOT all noisy when new...
What a treat you've had already with that car.  Keep at it !!
Kevin MacBride
« Reply #66 on: 25 March, 2012, 09:45:14 PM »
Not only is the gearbox nice and quiet, you'd never suspect it was 'crash' 1st. Also the propshaft doesn't vibrate and the front brakes don't judder. I'm beginning to think all these tales about Aurelia problems are old wives tales.
Later this evening I fired up my own car and went for a spin, first outing since last Oct. Now I have to say, there is a world of differance between the cars, considering mine has no sound deadening of any sort, no interior comforts, and no silencers (and a weird camshaft ala Mr Crowe RIP).
« Last Edit: 25 March, 2012, 09:55:41 PM by Kevin MacBride » Logged
2000 sedan
Fiat Multipla
Fiat Cinquecento
Kevin MacBride
« Reply #67 on: 29 March, 2012, 10:11:41 PM »
Well, it was too good to be true. Doing a few checks last night when on removing the rad cap, noticed that the header tank was empty. My fears were confirmed when I checked the dipstick.....and I was far from 'amazed'
Hopefully its only a head gasket and not something more serious. I've started to remove the heads, so will know more in a few days. The r/hand head looks the more difficult to remove. The steering shaft impeding access to the manifold. I did fit head gaskets to the B20 which was in the Mondello Museum, however that engine had been modified, and had head bolts rather than studs, which made things a little easier. It also had the studs which protrude through the inlet ports removed, and replaced with flush fitting 'dowels'
I suppose its not surprising, considering how long the engine was standing. Its a job I could do without !!
2000 sedan
Fiat Multipla
Fiat Cinquecento
ColinMarr
« Reply #68 on: 30 March, 2012, 07:08:34 AM »
I remember having to extract a few exhaust manifold studs to get one of the heads clear of the steering column. But this was with a standard engine and it proved to be an easier job than I thought it might be. The only worrying point was tightening down all those skinny head studs with the thought that they would snap at any time – and then doing it all again 1000 miles later!
Good luck.
Colin
« Reply #69 on: 30 March, 2012, 07:12:42 AM »
I can rememeber on-off-on-off-on-off before I found the crack in the inlet tract...   You'll get the hang of it soon enough, and for you that will be a "life-skill".  Alas I can't remember any details or tips other than being careful to get the inlet manifold gasgets (and in my case shims) the right way round so it sits correctly between the two heads.
HF_Dave
« Reply #70 on: 30 March, 2012, 04:24:21 PM »
The Lancia Motor club ireland will be attending the Terenure show, probably the best quality show in Ireland. It's a nice venue and the weather is normally good. We set up a BBq and do lunch ect, we really make a nice day of it. If anyone wishes to attend we can make a weekend of it by throwing in a run through the local scenery somthing not to taxing on the saturday, and a meal, and a few pints of the black stuff the night before  Grin Could be fun !! Grin
« Last Edit: 30 March, 2012, 04:26:59 PM by HF_Dave » Logged
My Current Cars:
1991 Thema station wagon
1989 Thema 16v
2011 Lancia Delta 3
1977 Beta sedan 2000
1975 Fulvia S3 1.3
1973 Flavia HF 2000 Coupe
1972 Fulvia S2 1.3
1989 Thema 8.32
**Other Makes**
2018 Alfa Giulia
1999 Alfa 156
2009 Fiat Du
Kevin MacBride
« Reply #71 on: 30 March, 2012, 11:46:35 PM »
Took the LH head off earlier this evening. Less than an hours work. Head came off very easily. The gasket is like sponge, I'd say the asbestos has crumbled to dust in places. The pistons dont look original. They are stamped 'made in england' with +20 and what looks like RSW stamped into the crown.
Re-capping the history a little, the engine originally broke a rod. (I have the original block). It was re-built with a new block (stamped with the same engine number). They must have used new liners as well, because the original liners are in the old block. That was almost 50 years ago, and its stood, never having been started for all that time.
As you can see, the head is almost like new.
Is it possible to pull the RH head without rmoving the brake resovoir. The column gear linkage also seems to be in the way. If I have time I'll have a go at it tommorow, although the little girl sitting in my own car may have other ideas.
2000 sedan
Fiat Multipla
Fiat Cinquecento
ColinMarr
« Reply #72 on: 31 March, 2012, 08:23:12 AM »
Kevin,
I doubt if the reservoir would get in the way - it didn't on mine. But I don't know about the gear-shift linkage - mine had a floor change. The business about having to re-torque the head nuts after a 1000 miles of use on a new gasket is serious. I think my failure to do this properly (slacken the tension before re-torquing!) was the reason why I had to do the job again.
Colin
« Reply #73 on: 31 March, 2012, 09:55:08 AM »
 Also on the subject  I have read the liners should be slightly proud of the block to achieve a good seal with the head/gasket.richard
« Reply #74 on: 31 March, 2012, 05:10:24 PM »
I enjoy these photos as much as the exterior.
Pages: 1 2 3 4 [5] 6 7 8   Go Up
