26 November, 2024, 04:15:58 AM *
Pages: [1] 2   Go Down
Author Topic: chugga and warby's simple guide to wire wheel balancing  (Read 9413 times)
chugga boom
Non-LMC Seller
« on: 25 November, 2009, 11:48:50 PM »
well folks, if you have been reading robin's thread about his wheels this is about their visit to wales to be balanced, at first inspection all seemed ok and no major drama's , only problem was that robins adaptor wouldn't fit my balancer, dad called again to machine out center bore to 40mm, this was finished in time for when i closed up this evening, i collected it and went about sorting out the balance issue, it became apparent after spinning up the first wheel that the tyres weren't infact fitted correctly and the beads of the tyre hadn't popped onto the outer edges of the rims making the tyres appear like those fitted to a clowns circus car bouncing up and down, also i had noticed the vaves were hardly petruding through the rims and at a perculiar angle, best thing to do was strip the tyres off the rims and start again...............................
1935 augusta lusso (chugga)
1935 belna saloon
1935 augusta lusso
1938 ardenne
1939 aprilia lusso
1958 appia s2
1963 appia s3
195? appia camioncino
1972 fulvia 1600HF
1976 fulvia coupe
chugga boom
Non-LMC Seller
« Reply #1 on: 25 November, 2009, 11:54:02 PM »
when the wheels were stripped there was nothing out of the ordinary and no damage to tyres and tubes so i set about re fitting them, plenty of soap was brushed onto the rim 1st and onto the beads of the tyre as the previous fitter had obviously had problems with getting the tyres to "pop on" propperly, when they were fitted plenty of maintanance spray was applied again to the bead area's (a trick we use on run flat tyres) to help them pop on, inflated , popped , RESULT  Grin ready for balance next
1935 belna saloon
1935 augusta lusso
1938 ardenne
1939 aprilia lusso
1958 appia s2
1963 appia s3
1972 fulvia 1600HF
1976 fulvia coupe
chugga boom
Non-LMC Seller
« Reply #2 on: 25 November, 2009, 11:58:48 PM »
next we come to balancing, the rudge type wheels need to be held on the balancer at both ends of the spline, most tyre fitters will simply use 1 cone to support the wheel and rely on the rear face of the wheel being "true" to but against the face plate of the balancer, this CANNOT be relyed on on this type of wheel , when fitted to the car the rear taper on the inside edge takes the load not the rear face of the wheel as my assistant will now..............
......show................
« Last Edit: 26 November, 2009, 09:59:57 AM by chugga boom » Logged
1935 belna saloon
1935 augusta lusso
1938 ardenne
1939 aprilia lusso
1958 appia s2
1963 appia s3
1972 fulvia 1600HF
1976 fulvia coupe
chugga boom
Non-LMC Seller
« Reply #3 on: 26 November, 2009, 12:02:04 AM »
also on the outer face where the spinner contacts the wheel most would put a cone inside the end of the spline, this too is inaccurate and NOT ROUND!! it is important to locate the wheel by the outer edge taper as again my assistant will demonstrate..............
1935 belna saloon
1935 augusta lusso
1938 ardenne
1939 aprilia lusso
1958 appia s2
1963 appia s3
1972 fulvia 1600HF
1976 fulvia coupe
chugga boom
Non-LMC Seller
« Reply #4 on: 26 November, 2009, 12:05:49 AM »
now.......more problems, because of the depth of the spline at the rear we had to use 2 cones to space out from the balancer so that the rear face plate didn't seat against the balancers face plate leaving the inner cone to wobble around doing nothing, these were both fitted to the balancer as shown below, then the wheel , the robins adapter and finally the locking handle
1935 belna saloon
1935 augusta lusso
1938 ardenne
1939 aprilia lusso
1958 appia s2
1963 appia s3
1972 fulvia 1600HF
1976 fulvia coupe
chugga boom
Non-LMC Seller
« Reply #5 on: 26 November, 2009, 12:11:42 AM »
the first "dynamic " ballance was the done, unfortunatly much to the nature of this type of "hand made tyre" it was proving impossible to get enough weight onto the wheel where needed, we opted for a simple "static " balance as used on most modern motorcycles and as we have done on my augusta and fathers astura, this involves just sticking weights to the center of the rim rather than each side of the rim, its not ideal on a modern car cruising at speeds of 70>80mph but ideal on a pvt or similar cruising at speeds of 50>60
« Last Edit: 26 November, 2009, 12:18:34 AM by chugga boom » Logged
1935 belna saloon
1935 augusta lusso
1938 ardenne
1939 aprilia lusso
1958 appia s2
1963 appia s3
1972 fulvia 1600HF
1976 fulvia coupe
chugga boom
Non-LMC Seller
« Reply #6 on: 26 November, 2009, 12:13:13 AM »
so there we go, another job done , my thanks to warby again for all his help with this challange, hope you all enjoyed  Grin
1935 belna saloon
1935 augusta lusso
1938 ardenne
1939 aprilia lusso
1958 appia s2
1963 appia s3
1972 fulvia 1600HF
1976 fulvia coupe
Dilambdaman
« Reply #7 on: 26 November, 2009, 12:22:09 AM »
Good grief! static balanced they may be but psychologically unbalanced they almost certainly will be. Shocked No doubt I'll have to lie them down in a darkened room for a day or two on their return. Minera Tyres North Wales Syndrome me thinks! Grin
Robin.
« Last Edit: 26 November, 2009, 08:11:07 AM by Dilambdaman » Logged
Robin Lacey 3222
1932 Dilambda
1992 Y10 GTie
2012 Delta Mk3
2013 Ypsilon 846
« Reply #8 on: 26 November, 2009, 12:22:37 AM »
Did Robin really know he was letting Daffy Duck and his Leprechaun assistant loose on his precious wheels Shocked
Well done lads, lets hope that's sorted out Modestines footwear once and for all. Grin
chugga boom
Non-LMC Seller
« Reply #9 on: 26 November, 2009, 12:28:18 AM »
ahh but did you laugh at our exspence Cheesy i suppose i should have said something like"THATS ALL FOLKS!!" Grin
1935 belna saloon
1935 augusta lusso
1938 ardenne
1939 aprilia lusso
1958 appia s2
1963 appia s3
1972 fulvia 1600HF
1976 fulvia coupe
chugga boom
Non-LMC Seller
« Reply #10 on: 26 November, 2009, 03:00:11 PM »
oh yes i forgot robin, didn't have a listing for a dilambda on my tyre charts for the tyre pressure's  Cheesy so stuck 40 psi in them you need to set them
1935 belna saloon
1935 augusta lusso
1938 ardenne
1939 aprilia lusso
1958 appia s2
1963 appia s3
1972 fulvia 1600HF
1976 fulvia coupe
Warby
« Reply #11 on: 26 November, 2009, 03:50:42 PM »
Stay tuned for more thrilling instalments. as i have said previously education is the key and we want to bring the joy of learning new experiences to you. If you have any suggestions for future features please feel free to contact us, however we will probably just do what we want anyhow, but try us you might like it! no guaruntees on that last bit though!
chugga boom
Non-LMC Seller
« Reply #12 on: 27 November, 2009, 07:51:04 PM »
WARBY IS A JUDAS!!!!!!!!!! Shocked
1935 belna saloon
1935 augusta lusso
1938 ardenne
1939 aprilia lusso
1958 appia s2
1963 appia s3
1972 fulvia 1600HF
1976 fulvia coupe
Warby
« Reply #13 on: 28 November, 2009, 06:27:04 PM »
Im no judas i did an ad for you too (please see below) I am available for any other ad campaigns and my fees are reasonable (well i think they are) please feel free to pm me or through my agent Mr Chugga Boom.
Dilambdaman
« Reply #14 on: 05 December, 2009, 05:03:11 PM »
Wheels came back from James during the week and I fitted them today. Then did 40 fantastic miles of vibration free motoring. James, you're a star!  Kiss
Oh, better give Mattie one too.  Kiss
Robin
Robin Lacey 3222
1932 Dilambda
1992 Y10 GTie
2012 Delta Mk3
2013 Ypsilon 846
Pages: [1] 2   Go Up
