25 November, 2024, 08:36:11 AM *
Author Topic: Clutch / Gearbox Fault  (Read 3660 times)
Nick Gramaglia
« on: 19 December, 2009, 01:15:32 PM »
Hi all,
I have a small problem with my series three Coupe when I start the engine from cold it turns over on the starter motor easier if I dip the clutch and starts no problem, but when I then release the clutch in neutral the car lurches forewad it does not stall and drives fine but I wonder if this is the start of something expensive.
Nick
ColinMarr
« Reply #1 on: 19 December, 2009, 01:55:49 PM »
Nick,
Mine does almost the same thing, but I wouldn’t describe it as ‘lurches’ forward, more like a gentle nudge. I think it’s just the cold viscous oil in the gearbox picking up some forward drive and is nothing to worry about. If the gearbox oil hasn’t been changed for a few years you might try doing that and a using modern oil, like Fiat’s Tutela 80W/90.
Colin
Richard Fridd
« Reply #2 on: 19 December, 2009, 02:04:14 PM »
if the clutch is not fully disengaging i think the only adjustment is by means of the wing nut on the cable.i do normally depress the clutch pedal when starting anyhow[especially from cold]to give the starter motor less load.richard
Peter W
« Reply #3 on: 19 December, 2009, 05:34:52 PM »
Mine does just the same.  The hand book tells you to depress the clutch when starting.  Clearly this reduces drag and gives the starter an easier time.
Kappa Coupe
Beta VX Coupe
S2 Fulvia 1600HF
Nick Gramaglia
« Reply #4 on: 21 December, 2009, 05:37:47 PM »
Thanks for the replies,I doubt the gearbox oil has been changed in the last 5 years so I will do that.
Regards Nick
Page created in 0.042 seconds with 21 queries.
