25 November, 2024, 07:49:03 AM
Welcome,
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News
forum.admin@lanciamc.co.uk
events@lanciamc.co.uk
- To Join the club go to
Home
Help
Search
Calendar
Register
Model Technical and Interest
Flavia
Clutch Release Bearing
Pages: [
1
Go Down
« previous
next »
Author
Topic: Clutch Release Bearing (Read 3968 times)
Angle Grinder
on:
10 January, 2010, 06:06:48 PM »
I have a distinct bearing rumble whenever the clutch is released.
I don't think that it is a problem with any of the Gearbox bearings as the box is quiet when you let the car coast in gear with the clutch pedal depressed.
Has anyone got experience of changing the Clutch Release Bearing on a Flavia 1800 coupe. Any advice or warnings. Can it be done with the engine in place or would it make life a lot easier in the long run to drop the subframe assembly?
I have a receipt for clutch replacement in 1999 so I'm hoping that there will be no need to replace the clutch as well, but I know that there is logic in doing it altogether.
At the moment, clutch slip is not a problem and there are no side-effects that spoil the gear change or clutch performance. I have only noticed a clutch judder on one occassion when pulling away from a standstill.
Previous cars:
1983 Prisma 1600
1991 Thema 16v i.e. SE
1988 Thema 8v Turbo
1992 Thema 16v i.e.
1983 Gamma Coupe (manual)
1993 Thema VIS
1994 Thema VIS LE
1990 Thema 2.8
rogerelias
MY 1600HF IN HEARTBEAT GARAGE
Re: Clutch Release Bearing
Reply #1 on:
10 January, 2010, 08:12:46 PM »
Hi May be of some help, i changed the gearbox in my normal sized garage at home, once the exhaust was out of the way it was striaght forward, undo driveshaft inner cv joints, and then treat as changing conventional rear wheel drive set up, i left subframe and engine in situ, lots of small nuts and bolts around bell housing but very simple job, mine was a Vignale but i would imagine the other variants would be the same.
FULVIA 1600HF LUSSO
1958 VELOCETTE MAC
Triumph Bonneville t120v 1972
1968 MGC ROADSTER
1958 Series 2 Appia berlina
Reply #2 on:
10 January, 2010, 08:25:21 PM »
I did same. Would add I found it necessary to get the car quite high to actually remove the gearbox to work on it as I used a Clark (from machine mart etc) transmission cradle that goes on my 3 tonne trolley jack.
Have done this a few times and i always manage to get the box back in albeit anothe trolley jack is generally required to control the small angle changes of the engine to get the box to mate.
You can do it on your own!
1998 Zeta 21. 12v
Charles
Reply #3 on:
10 January, 2010, 11:07:40 PM »
But clutch release bearings only rumble when the clutch is depressed - there is no load on them otherwise. I'm not familiar with the inards of the Flavia gearbox but generally if a box rumbles when in neutral with the clutch released it's more likely to be lay shaft bearings. Charles
Augusta berlina, Appia S3 berlina
Flaminia convertible 2.8 3c Touring
Beta spider S1 1600, Gamma berlina S1
Gamma coupe S1, Delta 1.6 multijet
Pages: [
1
Go Up
« previous
next »
Please select a destination:
General
=> About the LMC Forum
=> General Chat
=> Competition Information
=> Events 2024
=> Events 2025
=> Local Events
=> LMC Legends
=> Links
=> Pre-Lambda
=> Lambda
=> DiLambda
=> Artena and Astura
=> Augusta
=> Aurelia
=> Appia
=> Flaminia
=> Flavia
=> Fulvia
=> Stratos
=> Beta and Montecarlo
=> Gamma
=> Delta and Prisma
=> Ypsilon, Musa and Y10
=> Kappa
=> Thesis
=> Delta (2008-)
=> Commercial Vehicles
=> Other Lancia Models
Buy, Sell and Search
=> Members' cars for sale
=> Lancia vehicles for sale
=> Lancia vehicles required
=> Spares for sale
=> Spares required
Events Archive
=> Events 2011
=> Events 2012
=> Events 2013
=> Events 2014
=> Events 2015
=> Events 2016
=> Events 2017
=> Events 2018
=> Events 2019
=> Events 2020
=> Events 2021
=> Events 2022
=> Events 2023
Loading...
