26 November, 2024, 07:56:40 PM *
Pages: [1] 2   Go Down
Author Topic: Appia Buyers Guide  (Read 22176 times)
stuwilson128
Non-LMC Seller
« on: 10 February, 2010, 04:47:37 PM »
APPIA BUYERS GUIDE, produced by Don Cross of the Appia Consortium
The range of Appia cars covers Series 1,2 and 3 Saloons , Coupe, Convertible,Lusso and Zagato. The remarks in this guide basically apply to all variants  except the comments on bodywork where the Zagato is the exception as it has an all aluminium body on a steel tube frame all the other models have steel monocoque body shells. The guide is in six sections –bodywork, suspension, engine, transmission, brakes and electrics and fuel and carb.
Bodywork
The saloon  bodies are pillarless ie no B post,  check that the doors open and close easily, even with fairly rotten cars the doors will continue to open reasonably well. If they do not  then there is likely to be a terminal problem somewhere. Series 1 and 2 cars have aluminium doors but Series 3 cars have steel doors and rust tends to attack the bottom of the doors. Other areas to check for rust are the tops of the front and rear wings particularly at the A post  and C post. This is usually caused by mud and moisture lodged between the body and the wing and can lead to rot in the front bulkhead and rear wheel arch. Sills can also be a problem and if these are suspect check the floor panels. The chassis models can have similar problems – area to check is the water drain from the front windscreen  down through a tube hidden by the front wing on the Coupe, if this is not clear then there could be trouble in the bulkhead and inner wing. On the convertible double check the sills as weakness here will cause trouble in opening and closing the doors. The Zagato has a aluminium  panels attached to steel tubes and this is a recipe for electrolytic action  - difficult to check but if there is a problem it will be an expensive one!
Suspension
The front suspension is sliding pillar and in general is not a problem. If after a car has stood for a long while it can become stiff and will usually ease up with running. Difference in height between offside and nearside could indicate a tired or broken spring. Check for play in the front wheel bearings and for play in the sliding pillar.There is always a little in a well used car only if it excessive is it a problem.
Rear springs etc are rarely a problem but check for wear in the silent block bushes.
Engine
The engine is good for many miles and should retain oil pressure at mid point on the gauge in normal running but will drop to nearly the bottom of the gauge on tick over when hot. Excessive exhaust smoke can be caused by either worn pistons/ rings or worn valve guides. There is usually some smoke when starting from cold after the car has stood for a while this should clear after a short run. Otherwise all the normal checks one does when evaluating an engine apply.
Transmission
At each end of the prop shaft there is a rubber coupling, check for decay /splitting of the rubber. Back The clutch in general is no problem but if there is juddering when starting in first gear or particularly in reverse this can be oil on the clutch plate. The oil can get into the bell housing either from the rear oil seal at the rear of the engine or the seal on the main shaft of the gearbox. There should be about ½ inch play at the pedal , if there is more than this it either needs adjustment or the clutch plate is worn.
The gearbox is very reliable but has no synchromesh on first and reverse. First gear is straight cut and therefore is normally a little noisy but  if loud then it is likely that first gear is badly worn. Apart from the noise if first gear is badly worn then when driving the car it is likely to jump out of gear. If there is a tendency to jump out of all gears it is not necessarily the gearbox but the adjustment in the gear selection mechanism or worn bushes in the selection levers. Back axle is rarely a problem, it is not usually noisy nor have a whine.
Brakes
If set up correctly they are very good. If the car has stood make sure the plunger on the Fluid reservoir is fully up and the pedal firm with about ½ inch play before feeling the pressure. Common fault is pulling either to the left or right and this is caused by a variety of reasons non difficult to remedy. Handbrake is dependant on properly adjusted brakes .
Electrics
The electrics are Italian and subject to normal faults, if there is a failure in part of the system first check that all the fuses have clean contacts, corrosion occurs between the fuse and the contact, it is often sufficient just to rotate the fuses, this is worth doing even if there is no fault. All contacts and earths should be regular checked.
If the starter solenoid on Series 2 and 3 does not operate check contacts, if problem still exists run a line from the battery or a live source directly to the contact on the solenoid. If it operates then the problem lies in the ignition switch, probably the contacts in the back of the switch.
Fuel / Carb
Carb should be no trouble as it has fixed jets, play in the throttle spindle can lead to lumpy running at idle. Check for dirt in the float chamber. The Fispa fuel pump is renowned for letting the petrol drain back down the tube, which results in the starter motor having to work overtime to pump up sufficient petrol to start the engine, this can lead to burning out  the bridge holding the brushes in the starter motor. It is advisable to fit an electric pump to prime the system. There is a filter in the petrol tank and if the tank has any corrosion this can lie as a sediment in the bottom of the tank and block off the lower part of the filter. This will allow the bottom of the tank to have a few litres of fuel so that the low level warning light does not come on, but the fuel does not get sucked into the system.
* Appia Buyers Guide in Word Format.doc (30 KB - downloaded 508 times.)
Stuart Wilson 11175
1973 Fulvia Coupe 1.3
2000 Lybra SW 2.4JTd
2009 Delta 1.9 Twin Turbo
peterbaker
www.retro-speed.co.uk
« Reply #1 on: 10 February, 2010, 07:53:09 PM »
As this is a buyers guide I would have thought prices should be included. Its a good idea to copy Consortium material though.
« Reply #2 on: 11 February, 2010, 01:26:44 AM »
not really necessary Peter as that information can be found relatively easily, besides that it would be a real pain to keep updated, I originally wrote the Dedra Guide a couple of years ago, with so few good Dedras about these days I'd hate to even guess at the price for a good one, the good ones I've seen in the last few years have mostly sold for what anyone is prepared to pay for them, usually over the odds, whereas a rough one, or one without an MOT, are only worth scrap, or spares value.
chugga boom
Non-LMC Seller
« Reply #3 on: 11 February, 2010, 10:52:45 AM »
how do you value a classic car these days?? my augusta is insured and valued by the lmc at £10,000, yet a car far worse than mine has sold in  italy for 16k  Huh? my fulvia 3 was valued at 6k yet i sold it on ebay for 9k, i think these types of car are worth "what people are willing to pay" so pretty hard to give figures on on their value
1935 augusta lusso (chugga)
1935 belna saloon
1935 augusta lusso
1938 ardenne
1939 aprilia lusso
1958 appia s2
1963 appia s3
195? appia camioncino
1972 fulvia 1600HF
1976 fulvia coupe
JohnMillham
« Reply #4 on: 11 February, 2010, 05:31:27 PM »
Your Augusta is worth a lot more than that! I would think about double.
Regards, John
chugga boom
Non-LMC Seller
« Reply #5 on: 11 February, 2010, 10:30:36 PM »
Regards, John
this is my point, what value do you put on these cars?? i've just been sent a link by my dad to an augusta forsale in holland for 23,500 euro's , its not as nice as my dads yet his is valued at top book 15k
http://www.retrolegends.nl/UK/index.html
its about half way down the page have a look, interior is better than mine but bodily and under bonnet etc is probably not as good as mine  Huh?
1935 belna saloon
1935 augusta lusso
1938 ardenne
1939 aprilia lusso
1958 appia s2
1963 appia s3
1972 fulvia 1600HF
1976 fulvia coupe
sparehead3
« Reply #6 on: 11 February, 2010, 10:55:19 PM »
Perhaps the only way is to capture the prices (although I guess you don't know the actual sold value) and then you'll have the facts to give to the insurers when the value them ?
Regards,
Steve Pilgrim
chugga boom
Non-LMC Seller
« Reply #7 on: 12 February, 2010, 10:59:48 AM »
steve i think thats a great idea, whether it would make any differance i dont know but its a good idea to possibly get the valuation changed by the lmc, insurance companies always aim low on their values, when my evo was written off it was insured for 11k, i got paid out 8k ;less than i'd bought it for 2 months previous!!  Cry
1935 belna saloon
1935 augusta lusso
1938 ardenne
1939 aprilia lusso
1958 appia s2
1963 appia s3
1972 fulvia 1600HF
1976 fulvia coupe
« Reply #8 on: 12 February, 2010, 12:58:21 PM »
Don't the registras record cars seen advertised, sale price when known etc?  When I first got my Aurelia the club was able to give me the contents of "its file" which included an exchange and mart advert and some other history.
An idea to share the workload might be to have a single thread (sticky?) in each model's area to record "the market".  There's often threads on particular cars "seen on ebay" etc.  Today's interest (for me) was the 1967 Fulvia 1.3 Rallye which made its reserve at 1,307.
David
sparehead3
« Reply #9 on: 12 February, 2010, 01:18:38 PM »
I don't know whether anyone is recording these things : it seems like something that should be done. A single sticky thread would be easy to set up as a place for members to record pricing.
Finally (and on my list of things to do) this information can be entered into the online database to capture prices over time (in the same way I'd like to put in the MOT information over time).
It's certainly something we all have an interest in : agreed valuations.
Regards,
Steve Pilgrim
westernlancia
Appia S1 - 2006 Turin centenary Car of the Century
« Reply #10 on: 22 October, 2013, 07:27:34 AM »
Regards, John
I have seen a fair few Augustas advertised on Italian sites for 30K+ euros, and if I were James I certainly wouldn't sell that Augusta for under 30K!
00 Lancia Y Elefantino Rosso, 96 Lancia Y 1.2, 84 VW Golf GTi, 66 VW Splitscreen, 56 Ford Anglia, 56 Lancia Appia S1, 54 Ford Prefect, 54 Lancia Appia S1, 37 Terraplane, lovely old trailer, 10,000 vintage accessories
oldcaraccessories.com
JohnMillham
« Reply #11 on: 22 October, 2013, 09:16:09 PM »
Regards, John
. . . and I've just upped the agreed value of mine to £25,000! Perhaps I should have gone higher.
 Regards, John
« Reply #12 on: 23 October, 2013, 06:55:58 AM »
Regarding the question of up to date 'old car' prices, IMHO the only data worth recording and saving is a chronological list of prices for the make/model achieved at Auction together with the date and a v short description of the vehicle sold.
Sebastien
« Reply #13 on: 23 October, 2013, 12:15:51 PM »
Chris,
Good idea.
Check:
http://viva-lancia.com/auction/index.php
Some are there, sorry there are not too many Appias and Augustas on it.
It is very difficult to put an "honest" description on cars which one has not seen. However, for more information, one can access the web page of the relevant auction house and sale, and try to get more information, as the profiles of the cars are normally accessible many years after the auction.
westernlancia
« Reply #14 on: 31 March, 2015, 02:38:54 PM »
Quoting myself here (only the best sources!). Something which has exercised my mind in recent years is, does the value of foreign cars drop when the foreign currency drops?
When I wrote the above we were at close to 1 euro to the pound; today it is 1.38. So now 30000 euros, instead of being close to £30000, is under £22000.
The good thing about this for Brits is that it makes cars cheaper to buy (it's why I just bought my 'new' S1). The downside is that if the market 'thinks' in euros, the values of the cars we already own has dropped. I think it probably depends where the demand is - as Aprilias and Augustas are very sought-after in the UK, I doubt if their values have dropped much, because UK buyers will be a significant market driver. Likewise Integrales.
I suspect Aurelia values may have also dropped a bit, as a lot of the demand for those comes from Italy and Germany, as well as from the USA, and so their value will have 'corrected' a bit with the euro - the US dollar is a bit higher but still only around 1.50.
However, I know (from experience!) that there isn't a lot of Appia demand in the UK, partly because so few were sold there, and partly for the not-unrelated reason that no-one has the first clue what they are (I loathe Top Gear and their values, but one of their more memorable quotes is that a car can never be 'cool' if you have to explain what it is! Personally I strive to avoid cars that are 'kewl' (because cool = common), but 'coolness' does usually generate demand, which moves prices upwards - hence the rocketing prices of Integrales).
So I have a horrible feeling that Appia values have dropped 10-20% over the last few months. As I said, the upside is that we can buy them more cheaply. But the downside is that the ones we already have are depreciating fast! And so is my house!
Pages: [1] 2   Go Up
Page created in 0.231 seconds with 21 queries.
