22 December, 2024, 05:07:11 AM *
Author Topic: Fulvia series 1 fuel sender problems  (Read 3635 times)
zagatoman
Looking a lot better
« on: 02 May, 2010, 01:51:27 PM »
Is anyone able to help me on fixing my fuel gauge or sender unit on my series 1 Fulvia?
After having completed renovating my Fulvia the only thing I cant get sorted is the fuel gauge.
I have two wires that go from the fuel gage on the dashboard then to the sender, I have no movement on the clock although I have plenty of fuel in the tank. I have earthed each wire at the tank end, one eliminates the warning light the other moves the fuel clock to show full so I presume the clock is fine.
How do I test a fuel sender unit on a Lancia Fulvia series 1?
Is the sender the same on all series Fulvias?
Do I have to earth the tank?
Am I right in thinking the gauge is fine?
Paul
Series 1, 1.3 Fulvia Zagato 1969
ncundy
« Reply #1 on: 02 May, 2010, 02:01:41 PM »
Have you taken the sender unit out and checked it moves and works?
I've got loads of photos of it if you need.
zagatoman
« Reply #2 on: 02 May, 2010, 02:14:02 PM »
Hi Neil
Will be taking out tomorrow. If it all looks fine and moves but still will not register on the gauge is the sender at fault or do I have to do something else?
Should I run an earth from the tank?
Paul
ncundy
« Reply #3 on: 02 May, 2010, 04:47:11 PM »
This was the state of my sender (S1 also). As you can see it was completely corroded up. I took it to bits, cleaned and de-scaled it then re-assembled it. The other thing is to check that the float doesn't have a hole in it.
The circuit should be earthed via the fixings and the tank. Check it with a multimeter.
zagatoman
« Reply #4 on: 03 May, 2010, 11:31:15 AM »
Hi Neil, all sorted now.
You were right about giving it a good clean, now works perfectly.
Thanks for your advice.
Paul
Page created in 0.053 seconds with 20 queries.
