21 December, 2024, 06:37:11 PM *
Author Topic: Steering Question  (Read 4794 times)
Kevin MacBride
« on: 04 May, 2010, 11:24:13 PM »
I've a Fulvia Series 1 Coupe in for a few jobs. The last time I had it, I replaced all front balljoints, track rod ends and links. Plus any bushes on the suspension. The car has a leaking brake line somewhere.
The last time I drove it, it was fine, nice and tight and positive. Now its like the steering wheel is connected by a shaft made of porridge !!  Over in inch of free play, even mild use of the throttle results in the car veering wildly. It brakes in a straight line, so no problems with tracking.
Is it possible to 'adjust' free play in the steering box, or is it an overhaul job ?
2000 sedan
Fiat Multipla
Fiat Cinquecento
St Volumex
Owner of RetroPart
« Reply #1 on: 05 May, 2010, 07:34:36 AM »
Hi Kevin,
Our "Tigger" was just the same.  Sad But replacing the bushings in the steering box and adjusting the worm and roller solved the problem.
Omicron has the metal bushings for the S1 while the S2's are nylon/plastic
Kindest regards,
Guy McDougall
www.facebook.com/RetroPart
Rare Parts for Rare Machines
roddy
« Reply #2 on: 05 May, 2010, 09:22:15 PM »
Hello Kevin
Remember that the S1 Fulvia has a flexible 'fabric' type coupling at the end of the steering column where it enters the steering box.   They do deteriorate and start to de-laminate and break-up.   Omicron can supply new couplings, I understand.   Also it is possible to over tighten the adjustment of the steering box - must be done with the car on the ground and suspension settled, leaving just a slight amount of play on the steering wheel.
Regards - Roddy
Roddy Young
Dunfermline, Fife
1970 Fulvia Sport S1 1.3S
Taggart
« Reply #3 on: 06 May, 2010, 01:08:25 PM »
You should also have a good look at the idler box as this sounds the more likely from the symptoms you describe.
It is easier to overhaul than the steering box as you only need 1 puller to dismantle it.
If you try packing the idler with thick grease before you go pulling things apart and it improves the steering then that is where the problem is.
Might save you a lot of time to try this first.
« Reply #4 on: 06 May, 2010, 01:44:10 PM »
On the idler box (I have had to replace 2!) the give away is the car tries to drive off the road (left) on decelleration from say 70 mph.
St Volumex
Owner of RetroPart
« Reply #5 on: 07 May, 2010, 07:04:16 AM »
Remember that the S1 Fulvia has a flexible 'fabric' type coupling at the end of the steering column where it enters the steering box.   [/quote
A simple replacement I have found for this, is conveyor belt material.  Smiley
Guy McDougall
Kevin MacBride
« Reply #6 on: 10 May, 2010, 09:34:58 AM »
Thanks for the tips. I'm having a look at it this week, so hopefully I'll get it sorted.
2000 sedan
Fiat Multipla
Fiat Cinquecento
HF_Dave
« Reply #7 on: 10 May, 2010, 08:44:31 PM »
THere was an article in Viva Lancia a couple of yrs ago where the oil seal leaked, the fix was to pack the steering box with grease . The result was slightly heavver steering but not enough to make any major difference Wink
My Current Cars:
1991 Thema station wagon
1989 Thema 16v
2011 Lancia Delta 3
1977 Beta sedan 2000
1975 Fulvia S3 1.3
1973 Flavia HF 2000 Coupe
1972 Fulvia S2 1.3
1989 Thema 8.32
**Other Makes**
2018 Alfa Giulia
1999 Alfa 156
2009 Fiat Du
roddy
« Reply #8 on: 10 May, 2010, 10:45:18 PM »
Sorry to disagree, but I do not think it is a good idea, nor recommended, to put grease into a Fulvia steering box - it can 'channel' and cause dry spots.   Far better to put in Penrite Steering Box Oil.   It is thick enough not to weep past a seal (and probably contains properties to expand the tissue of the seals), yet is viscous enough to self seek a level.   It does exactly what it says it does on the label of the bottle!
Regards - Roddy
Roddy Young
Dunfermline, Fife
Page created in 0.035 seconds with 20 queries.
