22 December, 2024, 11:48:45 AM *
Author Topic: Oil Temp Gauge  (Read 4005 times)
Nick Gramaglia
« on: 18 May, 2010, 08:44:02 PM »
I have been trying to fix the oil temp gauge in my HF and run out of ideas, I have checked the positive feed to the gauge thats ok, the wire that runs to the sender is not broken and connected both ends (gauge and sender) I have bought and fitted a new sender unit but still the gauge needle sits just left of the 60, do I maybe need a matched sender unit ? is the gauge likely to be at fault or is there something else I am missing ? any ideas would be much appreciated
Nick
« Reply #1 on: 18 May, 2010, 09:41:10 PM »
Tap the guage when the oil is hot. Mine sticks in my Z( I took it apart and desticked it but after a year it sticks again) but my HF works fine v odd....
thecolonel
« Reply #2 on: 21 May, 2010, 11:03:53 AM »
Nick, first thing to try is :
take lead off sender, connect to earth point, gauge needle should go all the way
across, if it does then it's a faulty sensor or wire, if it doesn't it's a faulty gauge.
Geoff
neil-yaj396
Committee
« Reply #3 on: 21 May, 2010, 02:25:34 PM »
Geoff
Would this test work for an oil pressure guage as well? I've got a new sender unit which I haven't fitted yet. The guage showed a lower and lower  reading until it died last year on holiday.
Neil
thecolonel
« Reply #4 on: 21 May, 2010, 07:03:21 PM »
Hi Neil,
any gauge that uses a single wire sender will show same results
fuel, oil, water etc. disconnect sensor, earth out lead and gauge should show full reading.
Geoff
Nick Gramaglia
« Reply #5 on: 24 May, 2010, 01:31:52 PM »
Thanks for the advice
I have made some progress I have earthed the cable and the needle does indeed fly to the right, I have a brand new sender unit fitted and have got the car up to temperature and the gauge now is trying to work registering 64 when I tap the gauge it does jump up for a second so I presume it is now a case of a sticky needle, should it be reading half way at normal temperature ?
Nick
« Reply #6 on: 24 May, 2010, 04:32:32 PM »
Nick
My 1600 sport with sticky needle rarely registers above 75 which is low and I know the oil stat (it has a lancia oil cooler system) opens on a long hard run at c 85. My HF with same cooler gets up to 85-90 on a hard run (ie round goodwood!) so does not get to 100 ever in my ownership.
Page created in 0.364 seconds with 20 queries.
