22 December, 2024, 01:43:03 AM *
Pages: 1 [2]   Go Down
Author Topic: "Fay" Dumped Coolant Again!  (Read 13254 times)
chugga boom
Non-LMC Seller
« Reply #15 on: 27 May, 2010, 08:14:14 PM »
brian , quick test for you , as you have an infra red thermometer just scan it across the rad to make sure its not blocked again, my gussy rad had been rebuilt by serk marsdon however after a good run a load of corrosion had loosened up and circulated blocking the rad again, if alls ok whip the stat out and try it , hope you sort it soon james
1935 augusta lusso (chugga)
1935 belna saloon
1935 augusta lusso
1938 ardenne
1939 aprilia lusso
1958 appia s2
1963 appia s3
195? appia camioncino
1972 fulvia 1600HF
1976 fulvia coupe
« Reply #16 on: 27 May, 2010, 10:47:02 PM »
Thanks James,
I did try it while she was running but it's a bit dangerous with the series ! mechanical fan, but I wasn't sure how relevant it would be to try it with the engine not running, I think there's probably a good case for taking the thermostat out and give it a bit of a vigorous back flushing, do you reckon a jet washer stuffed down the heater hose would be chancing my arm Shocked
Peter W
« Reply #17 on: 27 May, 2010, 10:48:25 PM »
Brian,
I had a similar problem with a Rover 420GSI Turbo.  The 2nd day that I had it, it blew a hose off to the header tank whilst driving along a single track lane so was forced to trickle along for a mile or so before I could park up.  The garage where I bought it recovered the car and checked it for any damage but all seemed fine.  A couple of months later it dumped its coolant.  Again they checked it thoroughly, cylinder pressures fine, no sign of exhaust gasses in the coolant header tank.  A few weeks later, just days before we were going to drive it down to the Pyrenees, it did it again.  This time they had the head off and there was the tiniest mark of a leak between a cylinder and the water jacket.  The head was skimmed and I had no more trouble for the next 4 years when I replaced it with the Kappa.  We went on holiday in a new but very boring Peugeot hire car.
Kappa Coupe
Beta VX Coupe
S2 Fulvia 1600HF
« Reply #18 on: 10 June, 2010, 08:44:34 AM »
My temperature gauge does that as well.  I have ignored it for years with no problems.
Lavazza
« Reply #19 on: 11 April, 2018, 06:10:52 PM »
I know this is an old thread, but was there any resolution in the end?
Pages: 1 [2]   Go Up
Page created in 0.03 seconds with 21 queries.
