well with the weather turning bad, & the fact i still have no garage means i've had little chance to do any work on her. So yesterday i thought i'd keep her ticking over & fair play to her she started first time, then i looked into the passenger side footwell & there was about 2 inchs of water on the floor! I've taken out as much water as i could & left the windows open to try to dry out the floor! having not sat in the car for a couple of months i've no idea how long the water has been lying there, worried now about what damage its done....
You need to get the carpet and all the underlay off the floor, unfortunately it means a big strip out, the underlay soaks the water up like a sponge and will never dry out unless you do remove them, I had the same problem with my first Dedra, it had a car phone in originally as it was an ex company car, when they took the phone out they took out the rubber plug on the left hand side just below the windscreen drain channel, we suddenly found my wifes handbag was attempting to float in the nearside front footwell.
Same as yourself we got out as much wet as we could and even propped up the carpet and used a fan heater to blow under the carpets, but it still didn't dry it out enough, so the carpets had to come out, at which point we found that it had also run into the rear footwells, because it's a nylon carpet the carpet doesn't feel wet.
You could try using microfibre clothes to soak up the water as they are far more effective than anything else.
8227
