Author Topic: Journey to get Dedra back on the road.....  (Read 36161 times)
toby2449
  • Guest
Re: Journey to get Dedra back on the road.....
« Reply #30 on: 24 June, 2010, 08:47:06 PM »
ah you're far too modest Brian! yeah i agree, belts kinda terrify me, the thought of it going wrong terrifies me!!! But when i get the belts done, i'll go the whole hog & get the tensioners & water pump. Guy i work with does all the work on his own BMW 5 series, including belts etc... so might get him to quote me!
toby2449
  • Guest
« Reply #31 on: 01 July, 2010, 09:32:57 PM »
I've finally got a day off work, so tomorrow i'm going to change the rear lights (well thats the plan!) & if the weather holds up (we had 12 hours of non stop rain yesterday!) i might even take the suspension apart & see whats what!
  • Permanent resident
« Reply #32 on: 02 July, 2010, 01:05:32 AM »
OH Dear! Glutton and Punishment spring to mind :o
8227 8)
toby2449
  • Guest
« Reply #33 on: 02 July, 2010, 10:27:33 AM »
you might have hit the nail on the head there!! ;D
toby2449
  • Guest
« Reply #34 on: 02 July, 2010, 02:48:44 PM »
lights done! can't believe how big a difference they make! Now i just have to figure out how to get the connectors from the new lights to fit the cars original connectors...
« Reply #35 on: 03 July, 2010, 01:35:29 AM »
Looks great, can you not remove the connectors from the old block to fit in the new, or failing that cut & splice the cables.
8227 8)
Lindsay
  • Guest
« Reply #36 on: 04 July, 2010, 06:31:23 AM »
Those facelift lamps make such a difference to the Dedra. Good call to do that!
toby2449
  • Guest
« Reply #37 on: 04 July, 2010, 09:28:55 PM »
gonna take my time with the wiring, the last thing i wanna do is mess it up, didn't really get a chance to look at it today, hopefully will during the week.
i can't quite believe the difference the lights make, i always liked the originals, but got a brochure on the revised dedra off ebay, & thought, oohh they're nice, i wonder.... ;D
I took a bit of a chance though, couldn't find the 4 door version of the rear lights, could only find the estate's lights, but had a close look & took a chance on the 4 door & estate using the same rear lights, thankfully they're spot on!
toby2449
  • Guest
« Reply #38 on: 24 July, 2010, 07:37:14 PM »
finally we got some dry weather so back outside to do some more work, replaced the motor for the windscreen wipers, tested it &......nothing! Checked the connections (theres only two) all ok, checked the fuse, & it looks ok, any ideas what could be the problem???
« Reply #39 on: 25 July, 2010, 12:05:04 AM »
Earthing?
8227 8)
toby2449
  • Guest
« Reply #40 on: 25 July, 2010, 03:19:34 PM »
erm, how do i test for that?? ???
HF_Dave
  • Megaposter
  • Rust , What Rust !! I don't See any rust !!!
« Reply #41 on: 27 July, 2010, 10:07:06 PM »
Nice to see the new red lghts on a white car they look good. I spoke to Tony about the mod to the connecter I couldent quite rember what we did with them. It invulves removing the clip on the male connecter on the car then the plug wil fit. Are you in Dublin ? you could call and have a look at the car.
My Current Cars:
1991 Thema station wagon
1989 Thema 16v
2011 Lancia Delta 3
1977 Beta sedan 2000
1975 Fulvia S3 1.3
1973 Flavia HF 2000 Coupe
1972 Fulvia S2 1.3
1989 Thema 8.32
**Other Makes**
2018 Alfa Giulia
1999 Alfa 156
2009 Fiat Du
toby2449
  • Guest
« Reply #42 on: 28 July, 2010, 09:26:39 PM »
cheers dave, i had looked at the clips & thought about removing them but better to be safe than sorry! Not in Dublin, born in Dublin alright, but moved to Longford about 6 years ago, but thanks again!
toby2449
  • Guest
« Reply #43 on: 06 August, 2010, 09:48:19 PM »
well had to move the Dedra today as we're getting some work done on the garden behind the house, & the digger couldn't get through. She sounded rough, very lumpy, mis-firing, & when i got half wau around the house she died, took a while to get her started again & had to rev the nuts off it to get it to move again, & there was more smoke than i'd like out of the exhaust (there is a black covering on the ground where the gases come out of the exhaust when i had to rev her hard) Now i realise that she hasn't properly moved in about 4 years but i'm a bit worried there could be alot more work & expense in getting her back in proper working order.
toby2449
  • Guest
« Reply #44 on: 09 August, 2010, 08:24:32 PM »
might have been a bit over dramatic there!!! I ran the car for a bit yesterday & she seemed much better, i just have to remember she hasn't done any running for 4, maybe 5 years, & she's not gonna be perfect!! oops!
